When I sold my M8 a few years back, I didn't think I wanted it again but some how I found another one with a few Leica lenses and I'm
a happy camper now, I don't care if it's only 10 mega pickles the color is different enough to make me smile when I use and take see the
results, has Leica gone up all of them have. I just sold a non-working one for $700.00 I guess it went to China and it will be rebuilt or
used for parts, goes to show you you never know so don't sell anything if you don't have to.
Bob,
I’m so happy I have a camera arsenal built up. It took some time, but buy and hold worked well for me. I bought a lot of great stuff at good prices that I could never replace today.
You hit upon how a camera can become an extension of yourself and your identity. A lot of sentimental value goes on that I think some people dismiss.
I moved around a lot, and perhaps suffered a different kind of homelessness being a gentrifier, but having some connection to the past and a sense of history/legacy I think grounded me. At least I had something permanent in my life that was not going to change or go away.
So after decades of struggle, I struggle no more, and in the end I have lots f stuff I consider treasure because it is not replaceable.
Kinda funny the typo above, “Mega Pickles” to me is “Mega Pick-L’s.”
Yesterday I changed my mind again and built out the Ti Basso (Litespeed) mountain bike as a 1x11 XTR. The 2.35 Rocket Ron tires with bladed Mavic wheels is somewhat a fat tire bike. Looks mucho evil.
A while back I saw two U-Tube video’s: one was this guy who looked like an engineer/nerd who struggled installing a tubeless mountain bike tire on a Mavic UST wheel. He bemoaned hat it was not easy and reported it took him 2-3 hours to mount a tire.
I was learning about the new tubeless development at the time, then I clicked the link that he supplied from Mavic where a technical specialist pretty much installed a tubeless tire on a Mavic UST wheel by hand without any tire levers in about 40 seconds.
So the link mentioned the trick of centering the bead into the deeper channel to relieve the tension. Pretty evident that the engineer/nerd could not follow directions. He was really frustrated, angry, and pissed. In his video he called the Mavic video he linked as a lie. I found his arrogance and stubbornness really funny. It showed himself as being mighty dumb. LOL.
So I kinda learned that mounting tubeless tires is not so easy, but I also learned my own technic to make it easy. Know that I’m a lazy slacker. I use this “Pony” clothespin like clamp to pinch the tire so I can use both of my hands to work the bead around the rim. Not so bad and kinda EZ-PZ. The clamp makes it easy to center the beads into the deep channel in the rim for less tightness against the rim sidewall.
So the tires held pressure overnight without sealant. “I’m so clever.” LOL.
So pretty much I need sealant, but I think I will do a field test just to make sure the drivetrain is adjusted right. In the end the 1x11 is really a simple minimal setup, and I may have to rethink about going 1x11 and 2x11 XTR on the steel IBIS.
A triple is more complicated and problematic. I would rather ride than maintain bikes, so less maintenance works for me. I can see using another 1x11 on the steel IBIS. Hmmm. Also know that I have mucho stockpile of 11-40T and 11-42T cassettes.
There are also these “Wolf Tooth” chainrings that I bought. Some are elliptical for extending power range, but used on 1x drivetrains they feature a patented hooked teeth to prevent “chain-drop” on wide range geared bikes that have mucho gears and spread.
The Wolf Tooth chain rings work best with modern rear derailleurs that have “clutches” that control chain bounce. The idea here is not to throw a chain when on rough terrain.
So back in the day the wheels and rims were lighter, and also the tires in use today are fatter and wider. Modern bike have this rotating mass weight increase, especially wheels with disc brake capability where the centralized stress of a disc brake requires stronger spokes and a heavier duty rim.
The point being is that in the past bikes were lighter, but today the bikes are more bombproof and stronger. My bikes are a bit of a combination of both old and new. Modern drivetrain, bigger tires, but still in the realm of a “weight-weenie.”
So all this stuff is new to me. Kinda fun the learning, and in particular having the time to fully explore things in a childlike manner is a wonderful regression and experience. No rush, do deadline, and no stress or pressure. Pretty much a state of self-nurturing that is a pursuit of rather simple interests.
So now I have two built out mountain bikes, and I have to finalize the steel IBIS. I am very pleased with the way the two titanium mountain bikes came out. The Ti IBIS is heavier, but it is a 2x11 and has a savage overbuild using a lot of parts designed for a tandem.
”Maggie’s” literary agent informed her that some British publisher bought the exclusive rights. A pretty big advance was offered to ensure that the book would not go into a bidding war. Understand that Maggie already got an advance from an American publisher and now the foreign rights are up for grabs.
Maggie at this point is finishing up the second chapter, which is a long one.
Cal
