what's the problem with this film?
luuca
8:57 AM
italy
hi, can someone explain to me what's wrong with this?
trix400 developed with HC110 and agfa fixer on my jobo cpe, like every other B/W film I develop
could it be the fixer too old?
not every frame of the roll is affected, this one for example doesn't show the issue
crop
Reticulation? Or perhaps immediately processing the film when was still frosty (cold) - based on the outdoor picture with the young lady wearing a jacket? Was the film acclimated indoors before processing?
I can't explain the unaffected exposure.
Photographic Film Reticulation Due to Temperature Changes during Film Development
https://cmsw.mit.edu/wp/wp-content/u...evelopment.pdf
the develop was done 2 weeks after that shot...
could it be some errors in fixing temperature, causing reticulation?
that seems to me a possible reason.
I rinse under running water for 3/5 minutes... it is possible that temperature varied after I touched it at the beginning of the rinse (maybe someone in my house opened full cold water)
thanks to everyone, next time I will keep controlling water during the whole rinse process
odd that never happened, but I guess there's always a first time...
Why not use the Ilford method? When doing that you can feel/measure the water temperature before using it for wash. Reproduced blow for your convenience, quoted from:
https://www.ilfordphoto.com/wp/wp-content/uploads/2017/03/Reducing-Wash-Water.pdf
I use it; checked with Kodak HT-2 on blank leader: says OK.
Spiral tank processing method
For minimal water usage the following method is well
tested;
After fixing, fill the spiral tank with water at the same
temperature, +/- 5ºC (9ºF), as the processing solutions.
Invert the tank 5 times.
Drain the water away and refill. Invert the tank 10 times.
Once more, drain the water. Invert the tank twenty times and
drain the water away.
Finally rinse with a few drops of ILFORD ILFOTOL Wetting
Agent (1:200) added to the rinse water
