I too have somewhere read that Zeiss offered to coat older lenses after the war and that they also engraved the red T then. That explains some of the very early coated lenses with the red T. But others offered the same service after the war. An 18 cm Sonnar once offered on Ebay came with a receipt from 1952 for the "original Heraeus coating" it had received. Heraeus was a company that cooperated with Zeiss in the development of the vacuum chambers for the coating process. I too have an 18 cm Sonner that has been coated after the war by somebody, it has no red T. The rear lens is permanently fixed in its mount, so the mount was coated too!
I haven't seen any mention of the partly coated lenses. Here for once we have some contemporary information. In an article published by
Zeiss-Ikon in august 1941 we can read (my translation):
"For the time being the two outer surfaces are not being coated. Although the durability of the coating layer isn't that poor, you can carefully clean the surface with a soft brush, we have to take into account that lenses in the hands of non-professionals won't be treated with the proper care. That is why the two outer surfaces are left untreated". Later, already during the war, they found that by "baking" the lenses at high temperature they hardened the coating layer. In a footnote to the article the author informs that "at the moment" the only coated lens available from Zeiss-Ikon is 1,5/5cm Sonnar. Here are the 1,5 Sonnars I have examined:
June 1939 2553566 partly coated
August 1939 2610001 partly
August 1940 2675947 partly
2676058 partly
2676899 fully
March 1942 2792143 fully Arriflex
January 1943 2725231 partly
July 1943 2786838 fully
JakobN
Partly coated on the left, fully coated on the right. Below the coated metal part.
