Calzone
Gear Whore #1
Intercourse PA is right next to Blue Ball PA...
MFM,
On a map, not far from Intercourse, head north on Route 222 and go to Reamstown. Kinda funny that this is an Amish area.
Cal
If you thought Intercourse and Blue Ball, Pennsylvania were interesting, you should head to Kentucky and check out Big Bone Lick State Park, which is just down the road from Beaver Lick.
Phil Forrest
Cal,
Here around Philly there are old trail signs that have been left over from races from past years. I know that Blue Mountain has had some regular collegiate races as it is within the mid-Atlantic region of the NCCC.
On another note, now that you are riding upright, you should consider a suspension seatpost like a Redshift ShockStop or a perhaps a saddle with springs like a Brooks Flyer or at least a lot of flex like a Cambium. The upright position is going to put a lot more compression on your vertebral discs, as the usual, more aggressive leaned over position puts more weight on the legs and allows the back to flex more like a cat's. The farther upright you get, the more your spine is going to take the brunt of the vibration. Even high frequency, low amplitude road noise can cause sciatic and lumbar spinal irritation. Don't be surprised if you go through a few stem changes. I think I have four stems of varying length and angles, along with four different handlebars. I just changed to riding in a pair of cycling specific flat-pedal shoes by Specialized, instead of the RedWing boots I've been using for a year and they are night and day. As a result of the new shoes, I had to lower my seatpost 3/8" then I noticed my hands getting numb with my old Mary cruiser/mountain bar. I'd been saving up to get a Redshift ShockStop stem for a long time and finally pulled the trigger on it. That said, since the fulcrum point of the stem is right in front of the steer tube, I had to switch to a straight bar, so I stuck on an old Scott AT-2 bar with integrated bar-ends. The ShockStop stem is a complete revelation; no more road noise in my hands. I haven't taken a long ride on it yet but I'll get there and I'll get the elastomers dialed in better after some time on the road. My saddle is a Brooks Conquest which is a discontinued leather saddle on spring suspension designed for mountain bikes. It took me about six months of riding to get used to it again, but it's just about perfect. This is on the 1983 Univega that I'll be riding across the continent one day; until then I'm going to be commuting on it. I'll also probably be commuting on my 1981 Miyata 610 (if I get this job that I'm going through the HR motions right now for.) Anyway, take care of your back. At least get some saddle with a little bit of flex like a Brooks Cambium C19 or a seatpost that can absorb some of the hits from the road. It only takes 3mm of movement to herniate a vertebral disc. I have several that are bulging but not completely herniated and no stenosis in the mid- or lower-back; and my discs are probably 20 years more flexible than yours. Take care of your back so you can keep riding, and keep walking. It was just one minor accident that completely ended my competitive cycling career after I had already been selected for a spot at the 2010 national collegiate CX championships. It took me two years to get back on a bike after that accident and I still don't have the range of motion that I used to. I mention it because it was all soft-tissue damage, cartilage and tendons torn from bone. It's the stuff that doesn't grow back, and why I have a few inches of tiny rock-climbing rope and pitons stuck in my shoulder, holding my left arm on my torso. We don't have any such tech for the spine yet, only rods and fusion surgery once that cartilage is gone.
Phil Forrest
Whatever you do, don't cheap out on a Brooks saddle and get a "ratty old one." You will just wind up with further stretched leather and rivets in your butt. I rode a worn B66 that was "period correct" for my 1956 Rudge and wound up with a bad case of sciatica because of the position the saddle put my pelvis in. Get a B67 or a Flyer brand new, put on some Proofide and do the work to break it in like a good pair of shoes. Your butt and your back will thank you. They aren't even that expensive, as far as saddles go; some lens filters cost more. Just like all the other durable and expensive goods you like, the Brooks saddle can be one that you may have for the rest of your life if you take good care of it. I have three Brooks and they are all I want to ride now. I have a B17 on my Miyata, I've had this saddle since 2008. I have a B67 on my 1956 Rudge and it is perfection. I have a first-generation brass-rivet Conquest on my Univega; this saddle I've had since 2015 and has taken the longest to break in as it is a Brooks Professional (the heaviest of their leathers) over a set of springs. It cost more than the bike it sits on, but that's because I'm a mechanic and I brought that bike back from the dead and fully restored it. Regardless, the Conquest was still quite pricey then and is unobtanium NOS now.
If you don't go with a Brooks sprung saddle, take a look at the Redshift seatposts. They are really cool and take up the hits very well. Regardless, your back needs something, as does everyone's, otherwise, we will all need osteopathic doctors and neurosurgeons.
Phil Forrest
Cal,
Give Continental tires a try one day. As a matter of pure opinion, if you haven't already, give almost any other brand of tire a try. Schwalbe tires tend to have a lot of vulcanized rubber content and can feel really "dead". I love Panaracer and Continental, but prefer the latter. For MTB tires, the best ones ever made are now unavailable and haven't been seen since about 2002; they were made by IRC for the Yeti team and branded Yeti FRO "For Racing Only". When I was working at Albuquerque Bicycle Center, before I joined the Navy, I bought four sets of these because the writing was on the wall back in 1997 when Yeti was on top of the racing circuit. Then they got bought by Schwinn and the special tire made by IRC was no more. The last I saw of those tires was on my old 1996 S-Works that I sold to Rory at Beacon. IRC still makes some of the best tires out there. One tire I'd definitely avoid is the Specialized Armadillo range, which is a thick, soft rubber, almost sliding over a tough cross-weave of amarid fiber. Excellent at keeping out sharp bits but feels like riding on marshmallows and they corner just like riding on marshmallows. Badly, with little confidence. In my personal opinion, the only thing I'd ride a Schwalbe for is a tarmac-only cross-continent tour with known sections of broken glass and shards of metal, in which case I'd ride the Marathon Mondial Plus. Tires are a personal choice, I know and I've spent probably five-figures on bike tires since the late-80s, and while Schwalbe may make some of the most durable, long wearing rubber out there, railroad wheels are also long wearing but aren't known for comfort or good road feel. Just my opinion though.
I'm currently running Continental Contact Plus 26x1.75 and I love them. I'm saving up to get a set of Contact Plus Travel, their top-end touring tire in a 2.0" width, but they are north of $60 each depending upon supply availability. I've seen them as high as $98 in the last year. I'm not rolling anywhere far in the near term, so the "skinny" 1.75s I have now will work just fine for now.
I'm often reminded when I look at my bicycle tires that they are made by the same company that made the tires of my 1967 VW Beetle. Back in 1996, it was $23 per tire for my car and $42 per tire for my bike if I wanted Continentals on everything. Since I was working at a shop that sold Specialized, I went with the employee wholesale purchase and always bought the Specialized tires early in my career (the Ground Control set were great), so I'd spend $18 on my bike and just under $100 on my car.
Phil Forrest
So I'm home alone taking a break from being surrounded by an anxious family.
I did watch a lot of cartoons and learned a lot. Skylander Academie, and Captain Underpants kinda brain washed me into being like an 8 year old.
Cal
