Canon 28mm f3.5 or f2.8 on Leica M - Anyone one using one?
D
Deleted member 65559
Guest
I'm considering adding a 28mm lens to my Leica M. Usually I go from 21 to 35mm. Over the years I've used a number of Leica 28mm Elmarits, as well as the Canon 25 and several Voigtlander 28mm f3.5. 28mm is not a focal length i'd use often, and given the cost of the Color-Skopar these days, I thought I'd consider the Canon. I do like the small than Elmarit size. Also it might be a plus to have the lower contrast of the Canon vis-a-vis the Color-Skopar. Any comments on the Canon 28mm screw mounts from users, current or past?
I shoot digital, and have an M9. I have the 28mm f3.5. When I want to shoot 28mm I usually switch to my Ricoh, so I don’t shoot 28mm that much with my Leica. I did take it out a few months ago and did a bit of street shooting. I found the contrast to be very very low. But because of its size it is fun to shoot with. I also have an LTM Voigtlander 28mm F1.9, which is of course much larger; but it I were shooting 28mm more with my M9, I would probably opt for it for most occasions, not so much because of the speed, but because it is more contrasty, and, in my opinion, has better overall image quality.
Thank you all. Hugh, I'd be very happy with that quality.
If you want something small, and affordable, and you feel a bit adventurous, get the TTArtisan 5.6/28. Cheers, OtL
I looked at them, but 5.6 is too slow a lens for me. I often travel with one camera/one lens....and i'd be too restricted w that one. I know it works for Huss in sunny California....
I had the Canon 28/3/5. In a weak moment, I sold it. I read online that the 28/3.5 is sharper than the Canon 28/2.8.
I did too, which i would assume....but i also read good things about the 2.8....... that's why i'm digging for more user info to help my decision
Had an early Canon 28/3.5. Construction is of heavy brass. Focus ring is not so ergonomic because the lens is so small (tiny). Not an issue for me because I set it at F5.6 and set the focus at 2 meters to shoot street in NYC using a “Kill-zone.” Basically just like a point and shoot.
I found a later black Canon 28/3.5 that is kinda rare. The ergonomics for focusing are great, and a bonus is that it is lighter. The earlier version is more of a pancake lens though and is smaller. Not many black versions available, and seldom for sale. Same optics BTW.
I also kept the Canon 28mm VF’er from the first version 3.5. A really nice VF’er.
The lens is single coated, so the experience is kinda like shooting a V1 or V2 Leica 50 Rigid which is single coated as far as contrast. Does not have the heavy contrast of a modern lens. Note all the details in the midrange in some of the prints above. Low or lower contrast can be an asset and has its own punch.
I will go slightly off topic here because I’m of the opinion that a lot of people think lenses that produce high contrast in their rendering are sharper. The way the eye perceives and the way images are processed in the brain make the hard edges of definition of high contrast or higher contrast appear sharper.
The rendering is not modern like my 28 Cron V1, the corners are pretty good on the 3.5 though, but like I say not as perfect as a more modern lens. I kinda love the retro look.
The Canon 28/3.5 is kinda sized for LTM and well suited, but I love it on a M also. For more speed I have a Leica 28 Cron V1.
Cal
I have the Voigtlander Color Skopar f/3.5 and used it with my Leica screwmount camera. It's sharp edge-to-edge and quite contrasty. In fact for high contrast scenes I sometimes found it too contrasty. The images had a kinda 'hyper real' look to them and it was difficult to deal with even using Photoshop. I therefore bought the later black Canon 28mm f/3.5. Great ergonomics. The lens elements are quite recessed. Not quite as good edge-to-edge but doubt its noticeable in an actual photo. It did seem to handle high contrast scenes better so its the 28mm lens I use all the time now.
I have had several of the Color Skopars and agree. While they were sharp they were contrasty & a little modern. i often find myself working in contrasty light. At the current $700 USD for the CV 28, i think i will give the Canon a try
I found a nice copy of the Canon 28/2.8 last year on the ‘bay, from a seller in Japan. It’s a beautiful lens, very compact and of excellent construction. I haven’t used is on my 35mm film cameras as much as I thought I would when I bought it, but am keeping it nevertheless. Most recently, I’ve used it, with an adapter, on my Leica CL digital, where it stands in for a 35mm equivalent focal length (when I want to use a manual focus lens instead of the 23mm Summicron-TL). On the CL, it’s sharp with moderate contrast. Interestingly, Matt Osborne (aka Mr. Leica.com) did a comparision of 28mm lenses for Leica cameras last year, and the Canon 28/28 scored very highly in his test (I think the top scoring 28 was the more recent version of the Voigtlander Ultron 28/2.0, but the Canon wasn’t far behind).
I should add: I also have the Skopar 28/3.5, which is a super, and super small, 28mm lens. I routinely take that lens with me on hikes in the mountains, in combination with a 50. It produces outstanding images on black and white film, with good contrast and sharpness. There are examples of photos with this lens over on my Flickr. F.3.5 is a bit of a limitation, which is one reason I bought the Canon, but if you don’t need a wider aperture than f3.5 and can find a good copy that doesn’t break the bank, I would recommend it highly.
I happen to have all the three 28mm lenses mentioned above: Canon 28/3.5 chrome, Canon 28/2.8 chrome, and VC28/3.5 black.
I took some random test shots with each lens on M9M out of my window and attach three similar pictures here for your comparison. (All at f3.5)
Canon 28/3.5
Canon 28/2.8
VC28/3.5
(If you click on the attached image, you would see a larger 2048x1363 image. The difference in full size 5216x3472 is even more obvious. Caveat: these pictures are for lens evaluation only, no aesthetic value 😀)
So who is the fairer of them?
