Andy Kibber
I've often found that I like to use a 50mm lens outside and a 35mm lens inside. Not that I'm any HBC.
Or just split the difference and use a 40mm lens all the time.
Evergreen States
Francine Pierre Saget (they/them)
Kingly choices
Pál_K
Cameras. I has it.
Something anyone with a zoom lens, or access to one, and an SLR can easily determine which focal length “looks right” for a lens they want to casually walk around with. What I do is look at various scenes from some distance, zoom in and out until what I see “looks right” and then look at the focal length on the zoom. Amazingly, for me it’s about 50mm. Maybe this is because I used a 55mm lens exclusively for 15 years that I just naturally like that view.
There used to be a device that directors of films used - you could hold it to your eye and adjust it for the framing you wanted - the device would then indicate the lens focal length to use on the ciné camera.
raydm6
Yes, the Director’s Viewfinder. I always wanted one of those.
Alan Gordon Enterprises Mark Vb Director's Viewfinder
https://www.alangordon.com/sales/our-products/mark-vb
Retro-Grouch
Required accessories: a black beret, a long cigarette holder, and a megaphone. A folding chair with your name on the back is optional, but recommended.
raydm6
Retro-Grouch
...and a riding crop. Think Dom DeLuise in "Blazing Saddles".
Yokosuka Mike
Abstract Clarity
Sometimes people who aren't trying so hard get the best results.
There you have it! The secret to success! It has served me well all these years.
All the best,
Mike
Erik van Straten
pvdhaar
Peter
There was a time when lenses couldn't be wide enough for me; for a while I used a 10-18mm (albeit on APS), but slowly I'm again gravitating back to the 50mm.The 50mm is simply the best focal length for 35mm photography.
kshapero
South Florida Man
I will never forget showing a photo of an interesting man sleeping on a park bench. One viewer observed that if I had used a 35mm lens I would not have cutoff his legs. That really stuck with me.
Benjamin Marks
The guy was the preeminent artist of his age in his medium and genre. I think this is pretty simple. He used a 50 because . . . he liked it. It matched his vision and let him do what he was compelled to do.
D
Deleted member 65559
Guest
.....or you could have taken a step or two back...& recomposed. I'm a 35mm guy so i often take a step or two forward.I will never forget showing a photo of an interesting man sleeping on a park bench. One viewer observed that if I had used a 35mm lens I would not have cutoff his legs. That really stuck with me.
Retro-Grouch
This sounds like the old "zoom with your feet" advice. Unfortunately, I think it's poor advice. Every focal length has its own look, and imposes that look on the image. That's why commercial photographers don't use wide angles for portraits. As always, it's best to use the right tool for the job, provided you have the time to switch lenses, or at least know how your lens will "see" a given subject......or you could have taken a step or two back...& recomposed. I'm a 35mm guy so i often take a step or two forward.
D
Guest
Well it might be poor advice, but the difference between cutting off someone's feet in an image and not doing so....doesn't typically involve changing lenses.....This sounds like the old "zoom with your feet" advice. Unfortunately, I think it's poor advice. Every focal length has its own look, and imposes that look on the image. That's why commercial photographers don't use wide angles for portraits. As always, it's best to use the right tool for the job, provided you have the time to switch lenses, or at least know how your lens will "see" a given subject.
Retro-Grouch
Well, as I said, provided you have the time! It's an imperfect world...Well it might be poor advice, but the difference between cutting off someone's feet in an image and not doing so....doesn't typically involve changing lenses.....
boojum
Ignoble Miscreant
I have just re-read most of this thread. Great dream-spinning and speculation about HCB. What is in my mind is that he was an affluent gentleman, trained in art as in painting and drawing. He was French gentility to the point of almost a stereotype with the wit and humor of the country and class. The French enjoy life and a good joke and admire quick minds. As for HCB in particular he has said it many times, he used the camera as his sketchpad. To wit, as if he were gathering images for use in a greater work later. Sketchpads are white paper and charcoal or more often a Conté crayon. So B&W was just how he would think in sketchpad terms of what he was gathering.
And he sure did not seem to be puffed up about himself. The really good can be quite humble and self-effacing even if only to deflect praise and admiration. He has left a huge impression on all who wander streets, camera in hand. He is not the only one to have done so but he surely is one of the giants. I think we are all better for knowing him.
Keith
You'd think that by now someone would have changed the thread title from 'uses' to 'used!'
This has been a post from your concerned grammar police representative!
raydm6
JoeV
Thin Air, Bright Sun
And if you hadn’t cut off his legs, he wouldn’t still be sleeping!I will never forget showing a photo of an interesting man sleeping on a park bench. One viewer observed that if I had used a 35mm lens I would not have cutoff his legs. That really stuck with me.
