Nokton48
Nokton48 Hi, regarding the Aviphot 200, is your perforated or not? I recently bought three reels and was expecting double perforated. But after loading one cassette, I found out it was actually not perforated at all and cannot be used in the Hassy A70 cassettes.On another note, what kind of ISO do you use for the Kodak 2402 Plus-X Aerographic from India? I only have Clayton F76 (similar to D76) and Ilford DD-X developers.
If somebody here wants to pursue it, Hasselblad A70 Mags can be adapted to run unperforated 70mm film. A cog of the proper specs would need to be manufactured and tested. I have ONE left and it's worked for me, actually I had a Kiev88 that took Blad backs, and I used that to shoot unperforated 70mm. Somebody should take this up and report here. It's quite doable, and it's reversible, too.
Cal's friend Devil Christian popped one of mine and put it up on his website. The other factor is finding the right size rubber gasket to go onto the new sprocket. There is a washer in there that needs to be just like the original cog setup, so watch it. My originals I bought on Ebay twenty years ago, and were machined out of aluminum. Would be easy to make, but I am not a micro machinist (at least yet!) 😛
