It took you a little time to get back there again Godfrey, so let us not be disingenuous. You were using a CL for awhile, then you tried the Pixii and then you decided the M10 Monochrome was what you really needed. ...
Not sure where you were going with this "disingenuous" notion, jsrockit. I cannot see how I could possibly be construed as being insincere in my statements. The history isn't as you pose it.
I've had the CL since 2018 and it had become my main digital workhorse camera. I started having difficulty using the CL in sunlight about a year and a half ago. I knew an optical rangefinder would solve the problem, but then the discussion of major revisions to the hardware of the Pixii came up, and I decided to try one to see if it was a suitable replacement for the CL for my daylight shooting, and maybe save a couple thousand dollars.
After all, it's the same format, I have all the lenses I need for the format (same ones I use on the CL, since I only use M and R mount lenses on it), and it's about the same form factor.
Sadly, the Pixii had significant flaws that get in the way of my usage ... for instance, amongst other things, the viewfinder and rangefinder were great but the choice of settings display made it just as difficult for me to make exposure settings in sunlight as it was difficult to see the EVF in the CL. All in all, I deemed it not a useful tradeoff.
However, testing the Pixii in its mono mode brought me back to the fact that I'd been wanting an M Monochrom since they were first announced, and the concept still appealed to me. So once I determined that the Pixii was not the solution to my problems and returned it, I ordered the Leica M10 Monochrom. I have all the lenses that I need for that camera too, the same as the ones I use on the CL and used on the Pixii.
BTW: I still have, and still use, the CL. I have and use it for the things that it does well for me ... Color capture, early morning and evening work outdoors, tabletop and macro, etc etc, which are what I originally bought the CL body for. It's a lovely camera; I just can't see the display in the viewfinder very well in bright sunlight which affects my ability to focus and frame properly. I can manage it, but it means I use it less often than I might otherwise.
Whether you can or cannot afford, or want to spend the money on, a $10,000 camera, or whether getting one is difficult because you choose to live somewhere that places additional costs and accessibility barriers to the purchase, etc etc, is neither here nor there. It does reinforce what I said:
"... nattering about how much something costs is a sure sign that you can't afford it, or that the thing has lower priority to you than its price warrants. ... " I categorize from your statements that the latter is the case, it's not a priority to you. That's just fine. All the rest of your discussion is, well, the subject of the thread at large. The fundamental question: "Is there enough market for someone to spend the development money and produce a low cost but decent digital RF camera?" has been opined about for five or six pages now, and there is no resolution to it.
A camera that works the way I want and produces what I want
is a priority to me, and the M10 Monochrom is definitely meeting those requirements. The result is that I'm perfectly happy to have spend the money for it, and I'm getting a lot of satisfying photos with it.
If some odd miracle happens and some enterprising nutty folks produce a high quality digital rangefinder for under a thousand dollars, some day ... Well, in an infinite universe, there is a finite chance of nearly anything happening somewhere, sometime. Presuming it happens, I'll likely try one of them out too ... because I too like cameras, like the different solutions and compromises that camera manufacturers have brought to market, etc etc.
G
"Equipment is transitory. Photographs endure."
