Rob-F
Likes Leicas
Looks like a version 1, since the lens hood is evidently detachable, since it has its own catalog number.This one sells for less than $3k:
Yes, it is the slight depression in the surface. The error in focus in your lens is "around" 0.04mm. When adjusting a Sonnar 50mm F1.5, I find that is has to be done within 0.01mm. That slight depression is a fine adjustment for deviation in the focal length. An internal mechanism translates the 75mm focus to the 51.6mm motion expected b the camera.I don't seem to see a cut in the cam. Where should I be looking? Is it what looks like a slight depression in the surface?
The cam can be rotated? That's great news! I was starting to worry, after another post said these problems are fixed with tape!
You need to be careful when shopping for these "collectible" lenses as sellers may claim the lens to be Version 3 when in fact it is Version 1, say.
In one part of the ad it states "collapsible hood" while in another part the lens hood catalog number is listed.
There is a link "Full Specs" given:
Full specs
BUILT-IN LENS HOODYesMINIMUM FOCUS DISTANCE (M)0.75FILTER THREAD (MM)60MAXIMUM APERTURE - TELE (F)1.4APERTURE BLADES10MAXIMUM APERTURE - WIDE (F)1.4YEAR OF RELEASE1980LENS MOUNTLeica MIMAGE STABILIZATIONNoMINIMUM APERTURE (F)16AUTO FOCUSNoWEIGHT (GRAMS)560
The 75mm Summilux we've been discussing was indeed from there. after changing my mind back and forth some 8 or 9 times, rationality won over emotion and I sent it back. Much too much anxiety and worry. If I ever decide to buy such an expensive item again, I'll get it from a reliable seller such as an RFF member or sponsor. Thanks for all the help in sorting this out.flEaBay is a deceitful place.
Agreed. Bring along some slices of bread and a bit of mustard to go along with the baloney.The seller just told me that his "supplier" told him that "the problem" is that the lens was adjusted for a film camera, while the results I got were obtained on my digital Leicas. Sounds like baloney to me. I use all my lenses back and forth between M9, M7, MP, M5, etc.
Right, I have sent it back and the tracking shows it has been received. I'm a little anxious about getting a refund as there was a snafu with the tracking number; so I've got my fingers crossed.There is definitely no difference in calibration between a correctly set up 75 Summilux between film and digital. Film is more forgiving, but otherwise the calibrations are the same.
Whatever they say stay firm and send it back.
Marty
There is a difference in calibration, albeit slight but Freakscene is right; stick to your guns with this seller.There is definitely no difference in calibration between a correctly set up 75 Summilux between film and digital. Film is more forgiving, but otherwise the calibrations are the same.
Marty
It's all done. Money's back in the bank. Seller is honest and very motivated to protect his eBay reputation.I would not send payment of such a large sum without first making sure that the seller is someone you can trust.
Hopefully, you will get back your full payment very soon.
There is a difference, there isn't a difference; it would really be helpful and informative to have some actual data about this. I don't believe I've seen anything about Film vs digital focus calibration in the LHSA Viewfinder. Nothing about it that I have seen for Nikon, either. Anyone have any references?There is a difference in calibration, albeit slight but Freakscene is right; stick to your guns with this seller.
We may be talking at cross purposes. Leica built some new equipment to do this, but when I had mine done at Wetzlar and watched while the technician do it, they told me that the focus point for adjustment for film and digital was the same, but the tolerances were tighter for digital. I don’t have any references, but I am very confident of what I was told.
Marty
