Nice capture, Mike!! You must have been quite close to her. Her face is very sharp; looks like you shot this wide open or close to it.Another face in a crowd![]()
Sony A7III, Voigtälnder 40mm f2.8 Heliar Aspherical VM lens
Sony B&W in camera jpeg
Yokohama, Japan - February 2023
Image resized smaller than original
If you add a screw mount to M mount adapter you can choose which frame lines you get (depending on the adapter).is there any real difference between the ltm v M mount versions?
@Yokosuka_Mike , really like your work with this lens. 🙂
As noted at #38-40, I use the black Rayqual adapter between a VC 2.8-40 ltm and the Leica M 10-P, which IMHO is even better than adapters by Voigtländer or the old original Leica ones.Is anyone using the black version on an m10? I read in many reviews that it has issues with the camera, it doesn't recognize it has a lens attached due to the black coating on the lens base. I prefer to get the black version, but this sounds like an issue since I want to use it on an m10. I thought about getting the m39 version and buying an adapter, but I am not able to find any adapter with good reviews.
