Erik van Straten
Yokosuka Mike
Abstract Clarity
Walk on by
Sony A7III, Voigtälnder 40mm f2.8 Heliar Aspherical VM lens
Std. Sony B&W in camera JPEG
Yokohama, Japan - April 2023
Image is lower resolution than original
Bingley
Nice capture, Mike!! You must have been quite close to her. Her face is very sharp; looks like you shot this wide open or close to it.Another face in a crowd![]()
Sony B&W in camera jpeg
Yokohama, Japan - February 2023
Image resized smaller than original
Yokosuka Mike
Abstract Clarity
Thank you, Bingley, it's kind of you to view and comment on the post.
Yes, I was close to her, about an arms length away. And, the lens was wide open (f2.8). I used scale focus; I found on the 40mm f2.8 Heliar if I line up the center mark on the lens barrel with the red mark on the outside edge of the lens it's perfectly set for close up work. It was a thick crowd, I doubt she noticed me.
All the best,
Mike
mnutzer
no title
mnutzer
no title
Yokosuka Mike
Abstract Clarity
Taking pictures to share with others
Yokosuka Mike
Abstract Clarity
Talk'n 'bout stuff
Yokosuka Mike
Abstract Clarity
The half hearted thumbs up!
Yokosuka Mike
Abstract Clarity
Snap shot of a Boy's life
Whitten
If you add a screw mount to M mount adapter you can choose which frame lines you get (depending on the adapter).is there any real difference between the ltm v M mount versions?
The 40mm brings up the 50mm frame lines on my M240, which I'm fine with, but if you use a different adapter you can get 35mm frame lines.
Yokosuka Mike
Abstract Clarity
Liberty Call - Port of Yokohama
Sony A7III, Voigtländer 40mm f2.8 Heliar Aspherical VM lens
@Yokosuka_Mike , really like your work with this lens.
Yokosuka Mike
Abstract Clarity
@Yokosuka_Mike , really like your work with this lens.![]()
Thank you, splitimageview, very kind of you to say so.
The Voigtälnder 40mm f2.8 Heliar Aspherical VM lens is so tiny but it sure packs a punch! I wish Cosina would make a whole line up of them in the standard VM sizes (28mm, 35mm, 50mm, etc...) ; if they did I'd buy them all!
All the best,
Mike
Yokosuka Mike
Abstract Clarity
Hello!
Yokosuka Mike
Abstract Clarity
A lovely day to be out and about
Std. Sony color in camera JPEG
Yokosuka Mike
Abstract Clarity
I'm not shooting from the hip
She's standing on a wall
AlejandroI
Is anyone using the black version on an m10? I read in many reviews that it has issues with the camera, it doesn't recognize it has a lens attached due to the black coating on the lens base. I prefer to get the black version, but this sounds like an issue since I want to use it on an m10. I thought about getting the m39 version and buying an adapter, but I am not able to find any adapter with good reviews.
mnutzer
no title
mnutzer
no title
As noted at #38-40, I use the black Rayqual adapter between a VC 2.8-40 ltm and the Leica M 10-P, which IMHO is even better than adapters by Voigtländer or the old original Leica ones.Is anyone using the black version on an m10? I read in many reviews that it has issues with the camera, it doesn't recognize it has a lens attached due to the black coating on the lens base. I prefer to get the black version, but this sounds like an issue since I want to use it on an m10. I thought about getting the m39 version and buying an adapter, but I am not able to find any adapter with good reviews.
In any case, the Rayqual adapter covers the small window on the bayonet of the M10, where when there is incidence of light, the camera electronics think that no lens is attached and therefore refuses to release the shutter.
