Would like help with sunpak mx112/Olympus Trip 35
oltri35
11:20 AM
Hungary
Hi! I am slowly starting to get in to film photography with one of my grandparent's Olympus trip 35 and I also found a flash that came with it. Now I got it working and all but for the life of me (and this just might be because I am stupid) I cant figure out how I should be setting my aperture on my Olympus to match the designated distance shown on the flash (pic below). If anyone could help me understand it I would be ever grateful!
Let's assume that your subject is at 3 meters/10 feet. Reading to the right the chart indicates different apertures to be used with different speed films:
- ASA (ISO) 25 requires F2;
- ASA (ISO) 100 requires F4; and
- ASA (ISO) 400 requires F8.
I hope this makes sense!
PS - You're not stupid! That chart isn't the easiest to make sense of for someone just starting out.
Determine the distance to your object. According to your ISO choose the right aperture from the chart on the flash.
Oh my goodness gracious I see it now! Thank you so much you're a lifesaver!
Flash Photography was one of the hardest things I had to learn...working with a digital camera really helped as I got instant feedback and then I was able to create my own Flash Guide for my setup. Today I can get good exposures within a shot or two.
Glad to help!
If you end up liking flash photography I'd recommend picking up a simple automatic flash. You set the aperture for the max distance from the camera according to the chart, and the flash automatically reduces output for shots taken at closer distances. The simple auto flashes I have can also be used manually at the flip of a switch.
- Greg -
Hi, you say in your post you got it working. Wondering what was involved in getting it working. I have one that did not have an old battery inside. No sign of acid leak damage. I cleaned the contact areas with isopropyl 99% alcohol. There is a little metal tab in the battery compartment area that I am wondering if it is making complete contact when the battery door is closed. This metal tab gets suhed down when the door closes. and appears to make contact both with the door and a metal contact. A fresh battery installed and NO sign of life whatsoever when turned on. Any suggestions greatly appreciated. Thanks.
Sometimes IPA isn't enough, try using an eraser, fibre glass pen or emery board on the contacts to remove unseen oxidisation.
