shawn
I have spent a fair amount of time exploring the menus and all good so far in setting it up the way I want. One thing I haven't ben able to achieve is turning off the monitor ... you can turn it off but once done you can't review images with it .., it totally kils it. I have set up the down button to disable it but that still leaves it back lit and showing information at the bottom so still using power. I've seen several video tutorials describing how to set the camera to VF or monitor instead of auto and then assigning a function button to toggle back and forth between the two but that doesn't seem to be an option on the Aii. Am I missing something obvious or was it just a choice from the Aii onwards?
Yes, I mentioned that lack earlier in the thread. The A7II does not allow you to assign a button to hard toggle between the LCD or EVF. It is a menu option only on that body. The A7RII does allow you to define a button to swap between the two. I used to have an IR converted A7II and the A7RII and this missing feature drove me a little nuts swapping between the bodies.
