Yes you may have acquired one of the adapters made from Nikon S helical from @jonmanjiro ?
I've just received the LTM/Contax adapter I ordered from this latest batch. I had a play with it last night; it mounts a range of 50mm lenses fine as expected (pre-war and post-war 50/1.5 Sonnars, a Jupiter 8M, and a Helios 103), but there's a fair amount of variance in how easy they are to mount, with the J8M in particular being incredibly tight to fit. The Jupiter 11 mounts fine, but my Jupiter 9 will not - I suspect that's down to the lens and not the adapter though, as that's always been difficult to mount on any camera, whether Kiev or Contax.His current adapter design is entirely Amedeo's own proprietory creation, with it's own helical and lens release design. I'm unsure if there are physical differences between older adapters and his current adapters with regards to lens compatibility.
Compatibility of Nikon S / Contax RF lenses on Leica M with Amedeo Adapter
Disclaimer: I thought about starting this thread in the Nikon forum, but decided to start it in this forum so it can be a combined resource for both Nikon and Contax mount lenses. Background: Lately, there's a lot of interest in Amedeo type adapters for mounting Nikon S-mount lenses and old...rangefinderforum.com
I think that I got it from Robert Jagitsch here at RFF. However, there was so much trading of gear at that time that I lost track.Yes you may have acquired one of the adapters made from Nikon S helical from @jonmanjiro ?
I learned something new! Very interesting.Oh well then you got the adapter from me! 🙂 I got the helical from @jonmanjiro, as there were some of the Nikon reissues that were having problems with the reissue helicals. So Nikon would swap out the helical with a replacement. He somehow got them to return the old helical as well, along with the repaired camera! The helical then went to Amedeo which he built into an adapter. The adapters with the black focusing scale were *so* nice looking, compared to the Kiev helicals he had been using...
The depth of field on a 21mm lens is pretty wide. Given that the 21mm Biogon is max aperture f4.5, you should be OK with using the Nikon version adapter, ie., the depth of field will overcome the focusing differences between the Nikon and Contax helicals. Link to DOF Master, using a Leica M9 as an example. You may of course use any camera on the listI had a question if anyone knew offhand. I want to mount a 21mm 4.5 Biogon with the LTM adapter. But I really want to get the Nikon version as I don't have any other Contax lenses. Do you think the Nikon adapter would be "close enough" if used with the Biogon? Or would it be better to just get the Contax version?
A blast from the past 🙂Oh well then you got the adapter from me! 🙂 I got the helical from @jonmanjiro, as there were some of the Nikon reissues that were having problems with the reissue helicals. So Nikon would swap out the helical with a replacement. He somehow got them to return the old helical as well, along with the repaired camera! The helical then went to Amedeo which he built into an adapter. The adapters with the black focusing scale were *so* nice looking, compared to the Kiev helicals he had been using...
