Yokosuka Mike
Abstract Clarity
Yokohama Chinatown
Sony A7III, Voigtälnder 28mm f2.8 Color-Skopar Aspherical (Type I) VM lens
Kenko M-E Adapter
August, 2023 - Yokohama, Japan
Image is lower resolution than original
Kenko M-E Adapter
Yokosuka Mike
Abstract Clarity
Yokohama Chinatown
Girls stay cool with battery operated fans
Kenko M-E Adapter
Kenko M-E Adapter
Yokosuka Mike
Abstract Clarity
Yokohama Chinatown
Kenko M-E Adapter
Kenko M-E Adapter
Yokosuka Mike
Abstract Clarity
One from Yamashita Park
Kenko M-E Adapter
Kenko M-E Adapter
mfunnell
Shaken, so blurred
It probably is a really tough audience. Too many (eg. me) already have pretty good 28s - I have the Voigtlander 28/f1.9 Ultron and M-Hexanon 28/f2.8, for example.damn, this is kind of a tough audience.
The late LTM Voigtlander 28/3.5 was an instant classic and much missed from the day it was discontinued, about 15 years ago.
Now a new much better 28/2.8 arrives in a choice of six tasty flavors and hardly any comments at all.
BTW, Fred Miranda found it a better lens overall than the Leica M 28/2.8 V2 at only $2800.
Each are good in different ways. A new 28mm kind of makes me go: hmmm - would I use this instead of one of those? 🤔
…Mike
Yokosuka Mike
Abstract Clarity
Yokohama Chinatown
Kenko M-E Adapter
Kenko M-E Adapter
maddoc
... likes film again.
Yokosuka Mike
Abstract Clarity
Yokohama Chinatown
Kenko M-E Adapter
Kenko M-E Adapter
Yokosuka Mike
Abstract Clarity
I received my copy of the LTM version this Monday. Shot a couple of frames with it already on film, need to scan. Here it is mounted on my M4 together with the Voigtländer 28mm metal VF.
I see you're using the 34mm Marumi UV filter too!
All the best,
Mike
maddoc
Yup, the only 34mm filter that I found in one of my drawers. I found a black 34mm filter on Amazon, Japan, that I ordered.I see you're using the 34mm Marumi UV filter too!
All the best,
Mike
pyeh
Member of good standing
Mike, so good to see you here after such a long time.It probably is a really tough audience. Too many (eg. me) already have pretty good 28s - I have the Voigtlander 28/f1.9 Ultron and M-Hexanon 28/f2.8, for example.
…Mike
Yokosuka Mike
Abstract Clarity
Yokohama Chinatown - Lunch
In August, ice water is like Champagne, so satisfying!
Kenko M-E Adapter
Kenko M-E Adapter
Yokosuka Mike
Abstract Clarity
Yokohama Chinatown
Over 250 restaurants to choose from - Searching for the right one
Kenko M-E Adapter
Kenko M-E Adapter
Yokosuka Mike
Abstract Clarity
Yokohama Chinatown
Kenko M-E Adapter
Kenko M-E Adapter
Erik van Straten
I have the Color-Skopar 28mm f3.5 LTM (2004?) in black paint. One of the most beautiful made (and optically superb) 28mm lenses I've seen so far. It would be great if anyone will do a comparison test with the new aspherical 28mm!
Erik.
Erik.
D
Deleted member 65559
Guest
Y Mike & Maddoc, can you give some general impressions of the lens? Admittedly photos viewed on a screen all look pretty good. How does the lens handle? How do you like the size....etc. Thank You.
maddoc
First impression, handling and size reminds me a lot of the W-Nikkor-C 2.8 cm f/3.5. Aperture clicks are firm but aperture setting is quite easily altered when using the knurled front ring for focusing. Reminder, only use the infinity lock lever for focusing to avoid this. Focusing is very easy and stays as set. Regarding size, the lens fits perfectly on my screwmount Leicas, that's why I bought this version of the lens. I have also tested it briefly with the Xpro3, where the FoV corresponds to a 42mm lens, no photos to show here as of yet.Y Mike & Maddoc, can you give some general impressions of the lens? Admittedly photos viewed on a screen all look pretty good. How does the lens handle? How do you like the size....etc. Thank You.
Below is a quick test shot on film (taken at 1/30s f/2.8), expired Neopan Presto (400PR), developed in Ilford ID-11. Scanned with Nikon Z7II & Micro-Nikkor 55/2.8 on extension tube, Intrepid enlarger head as light source and converted in Lightroom Classic using Negative Lab Pro.
Yokosuka Mike
Abstract Clarity
Firstly, I concur with what Maddoc had to say.
Secondly... for me,
I like to shoot “in-close” street photography using scale focus at wide apertures on manual focus lenses. It’s a dynamic style of photography, everyone is moving, including me. With some lenses this is difficult to do while other lenses can be more forgiving.
After only one outing with my Voigtälnder 28mm f2.8 Color-Skopar Aspherical (Type I) VM lens I can tell it’s very forgiving. After a couple of shots I was able to find the sweet spot on the scale and get main subjects in focus at f2.8.
I can say the same thing for the Voigtälnder 40mm f2.8 Heliar Aspherical VM lens.
All the best,
Mike
By-tor
If I didn't already have the 28/2 Ultron II I would have to have that type II, but the Ultron II is just amazing...
Yokosuka Mike
Abstract Clarity
The 28mm f2.8 Color-Skopar is also pretty good at the far away stuff too!
Clouds over Yokohama Bay
Kenko M-E Adapter
Kenko M-E Adapter
