Mackinaw
Think Different
- Local time
- 11:50 AM
- Joined
- Mar 13, 2005
- Messages
- 4,744
Agreed. If it actually comes to fruition and is priced right, I'll buy one.
Jim B.
Jim B.
It might if it is aligned with the face of the circuit board. Think there will be some limits to cameras based on how far the pressure plate will move back.Surely the sensor won't be in the same plane as the film would be?
"I'm Back" 16MP digital back
I like the idea,
but the prototype seems to be a bit clunky in design with its large bulge on the back,
plus the relatively small 16MP will likely be met without much enthusiasm.
Stephen
Maybe you could remove the pressure plate altogether. And use a thin sensor stack? I find it hard to picture given that the camera expects a <0.15mm "sensor".It might if it is aligned with the face of the circuit board. Think there will be some limits to cameras based on how far the pressure plate will move back.
The pressure plate is going to be holding the sensor in place. The camera doesn't expect any thickness, it expects that the focus point is just behind the film rail. Realistically, the sensor might (probably will) extend in front of the rail at least as far as the cover glass and IR filter. The sensor stack thickness has no real bearing on the focus point... just stuff ahead of it.The key is the imaging plane of the sensor needs to be at the proper position. If there is stuff (rest of the sensor) behind that it doesn't matter as far as focus is concerned. But it could be an issue if it sticks back to far and prevents the rear door from closing.Maybe you could remove the pressure plate altogether. And use a thin sensor stack? I find it hard to picture given that the camera expects a <0.15mm "sensor".
How are you planning on getting the flex cable from the sensor to the pack? It looks like it is designed to fit in the gap between the film door and the body.I plan on using the 105mm framelines on the SP when shooting with the 5cm F1.4.
