Vince Lupo
Whatever
Not wanting to get into a dispute over a set screw etc -- we're all friends here 🙂 . I actually contacted Jim Lager about this lens after I got it back in 2011 -- here is his reply:I'm just making comparison observations. 🙂 I don't doubt they delivered the 90/2 with M bayonet, just making a comparison to how they delivered the 35mm lenses.
Also the 35/2 and 35/2.8 that came with dedicated adapters both focused to 0.7m. These lenses that were originally shipped as screw mount only, focus to 1m.
"Greetings Vince, Thanks for contacting me. It appears there are two serial number groups
used by Ernst Leitz Canada for the early 9cm Summicrons. Between 1477001-1478500 and
between 1580001-1581000. These batch numbers are guides ....it is probable that not all
the numbers were used. Your lens is very early in the 1580XXX grouping. Gorgeous lens.
Did you get the hood ? The hood is impossible to find separately. Yes, Leitz glued permanently
the adapter. When I was at Leitz Rockleigh the service department would occasionally be asked
to remove this adapter to produce a screw mount lens. Dangerous procedure. Required heat.
Lots of heat to soften the adhesive. They would do it ONLY if the customer accepted full
responsibility."
Guess I was lucky that I was able to get the mount off with a moderate amount of effort using an M-mount rear cap.
