F
former member
Guest
The EBay seller has mistaken RF coupling with Autofocus.Wait, the rangefinder on the Leica will not work with this. This adapter doesn't have focus cam, a 50 is difficult to guess focus.
Slight aside to mention that RF coupling was marketed as autofocus back in the day.The EBay seller has mistaken RF coupling with Autofocus.
From what others have said and the research i've done, I just didn't know what exactly I was purchasing. What I would probably have to pay on the return shipping to Ukraine would be close to what I paid for the lens to begin with. So I think I'm going to keep it and look into some of the adapters that have been posted above.Let me offer a comment. If you're missing a part, you ought'a return the lens. My two cents worth.........
You would problably be best off selling as a Contax RF J-8 lens.From what others have said and the research i've done, I just didn't know what exactly I was purchasing. What I would probably have to pay on the return shipping to Ukraine would be close to what I paid for the lens to begin with. So I think I'm going to keep it and look into some of the adapters that have been posted above.
Then, find a correct lens for _your_camera.
If you want/need help, pm me. I will assist you.
That said, you have a nice lens there. Don't piss it away just because it isn't what you thought it was,.
We ((here at RFF) can make it work, one fucking way or the other. )
Take that as you will 😀
If you do decide to go that route, honestly... skip the "LTM" Jupiter 8. There are a lot of LTM 50s that are much less hassle for not a lot more money.I somehow didn't even think of reselling it as what it is and then purchasing the correct thing. I think that's the route I will go.
People will wax lyrical about the Jupiter 8 on here and elsewhere, but as I said previously, unless you get one that you know someone like Brian has fixed or are willing (and able) to do the work yourself, it is going to be a roll of the dice as to whether you get one that will work properly on your camera (and the likelihood is that you won't).
Unless, of course, you're using a FED or Zorki; in that case, grab an "LTM" Jupiter 8 and go nuts. They are fine lenses... in the right setup.
Wow, I never thought I'd see you defending Soviet gear, @Ko.Fe.; you're normally the first to belittle them!
That is a different animal, the C/K mounts are just lovely and work greatView attachment 4836695
Here's my jupiter-8 c/k mount on leica monochrom. It's a nice vintage lense with 3d pop, low contrast but works nicely 😊
No, note how close to the film plane the lens is? The rear element is right there at the rear flange. That's where the mirror is on an SLR. In the case of the J-9, the lens itself sits further forward in the barrel so it also works as an SLR lens.I know there is an M42 version of the Jupiter 9, but was there a native M42 Jupiter 8?
~Hibbs
The Jupiter 12 won't work with most external mount adapters even if you find one. The rear element is too large.Would love to find external bayonet adapter for my jupiter-12 & 9 lenses. But they seem hard to come by
