wrs1145
A native Texan living far from home.
I've been wondering about this question.
Thanks for your comments,
Bill
Bill
Whatever you've got....you eventually figure out what a particular lens can/can't do..
I prefer wides.....i have a soft spot for context.
https://flic.kr/p/2drLh1aThe 21mm is kinda unusual for street photography. The advantage is that you get immense depth of field and you can hip shoot all day long. The downside is that it's very difficult to organize what you get in the frame. And then, you have to get close, real close. Have a look at work that was made with this focal length, see if that's what you want. Raymond Depardon and Mark Cohen used it, and even they not always. Bruce Gilden uses a 24mm but the flavour is the same. Jeanloup Siff was a master of the focal length but he was doing fashion, not street, so he had time to organise his shots.
The 28mm is still challenging but nowhere near as challenging as the 21mm. There are many more examples of street photographers using one than the 21mm. I'd say this is the one to try first.
"Mainly I think this because I like peoples faces as the main subject."....Mike there you've made a choice & a preference...which is the way you see the world. We all define our own borders, or draw outside the linesWhat's best for street photography? A 21mm or a 28mm?
Good question.
I shoot a lot of street. In my humble opinion 21mm is far too wide for street unless you're combining an architectural or nature background with your main subject, or you're so close to your main subject (like less than 1 foot away) that you can get away with the whole wide angle thing. It can be done but I think it's difficult.
28mm is far more manageable than 21mm and (again in my opinion) more pleasing to the eye of the beholder. Main subject isn't lost in the background and there's plenty of peripheral stuff to add to the story.
In all of my years of doing street photography I think the best focal length is 35mm. Mainly I think this because I like peoples faces as the main subject.
Alas… whatever works, it doesn't matter, any focal length is fine as long as you're telling a story with your images.
All the best,
Mike
I haven't been to Saigon, but in France, where some streets are also very narrow, I have also found the 25mm Color-Skopar 4/25 to be quite wide enough. Having to keep track of what extraneous stuff may be getting included with an overly wide lens slows me down. In less extreme situations my 35mm lens seems best suited. I like my 35mm Summicron or Summaron on a .58 finder for being able to see what's coming outside the finder frameline. When the street is narrow, my 28mm Summicron is usually about right.In my experience in fairly narrow streets and alleyways in Saigon: a 21mm lens will make you work very hard; a 28 less so. You could also go for an in-betweeny: the excellent, cheapish, tiny, and lightweight Voigtlander Color-Skopar 4/25. Cheers, OtL
