das
Thanks so much to everyone weighing in on this thread. So cool to see folks using the Biometar and Planar on film and digital. Are you folks seeing any focus shift with the Biometar or the Planar? What is really nice about the Biometar is that it can be used with the Amedeo / Coiro adapters, whereas the Planar apparently cannot (without modification to the lens itself).
I don't know if you folks had run across Gigant Optik's review (South Korea) of the Biometar. Very nice photos.
gigantoptik.com
One thing that the Gigant review states that I don't quite understand is:
"Unlike the West German Contax IIa, which was slightly modified after the war, the flange back is set to the existing Contax I and II, so it can be used on the Nikon RF body without pin correction."
In case you have not seen it, this is also a very informative article about the development and evolution of the Biometar.
zeissikonveb.de
A comparison that I would like to do once I get a Biometar is against the W-Nikkor 35mm f/1.8. Although Nikon went symmetrical ala the Leica f/3.5 Summaron with the 1951 35mm f/2.5, it obviously used and then modified the Biometar (or "Xenotar") design for the f/1.8. I wonder how Nikon's addition of a two-element cemented rear group alters the Biometar's results at the 35mm FL. The Nikkor is absolutely outstanding at distortion control, but it is not so strong in the corners at the widest apertures and has quite pronounced focus shift.
[Zeiss] Carl Zeiss Jena Biometar 35mm F2.8
렌즈명: Carl Zeiss Jena Biometar 35mm F2.8발매년도: 1950년렌즈구성: 4군 5매 최단거리: 0.9m 필터지름: 43mm본체무게: 110g생산개수: 1,614 202 일반적으로 콘탁스 레인지파인더의 35mm 렌즈들은 Carl Zeiss Biogon 35mm F2.8를 필두로 개조없이 라이카에서 사용이 불가능하다고 알려져 있습니다. 그러나 별다른 개조 없이도 어뎁터를 경유하여 라이카 바디에서도 이종교배가 가능한 동독제 칼 짜이스 35mm 렌즈가 존재하는데요, 그럼에도 불구하고 Carl Zeiss...
Biometar | zeissikonveb.de
Carl Zeiss Jena Biometar. Biometar 80 mm f/2.8. Zeiss Zenzanon. OPREMA.
