Freakscene
Obscure member
Mine flares quite badly, I thought it was just my sample. I tried a deeper hood thinking it might help, sadly not.
Sent it to Leica, they said there was no problem.
When it flares, it flares fairly severely.
A lot of how much it bothers one individual photographer depends on individual tastes about light and angles. I found that with the v5 Summicron that I was losing shots all the time. A lot of my compositions seem to use the sort of light that provokes flare in that lens. With the Summilux ASPH I get flare less often, but it is pretty bad when I get it. It also changes things that in the meantime I switched from using black and white film to a Monochrome, so I could preview and change angle if I needed to.
The 50mm Summilux ASPH often gives me big washed out areas or huge flare arcs (see below) when it does flare. In the photo below, moving the camera maybe 20-25cm eliminated the flare. It is one area where some of the giant 50mm lenses for mirrorless cameras can do better.
