Brambling
	man, you look like a shoe today, (Iskra)
	I can’t say this for sure!)I have an otherwise OK Iskra with a tatty bellows and light leaks that I could try to repair, but I was wondering if its Agfa Super Isolette heritage means the bellows are similar enough to interchange or modify to work? The Agfa replacement bellows are available, though admittedly cost as much as I paid for the Iskra.
It's difficult to tell anything from a scan.Thank you Brambling. I thought you might be able to comment and help. This is an example of what I have. The bellows leak is probably the light smear on the left of the photo with an odd spot in the middle. The vertical bar on the right is probably the seam leak you mention, though I did follow the advice given several years ago on this forum and put some self adhesive black velvet tape inside the film recess on both sides before this roll of film. I will revisit that again as all the photos have the vertical light leak on what appears to be the loading side so I seem to have missed something. The leather on the outside front over that seam is intact but has contracted a very small amount due to age. I may try some temporary tape there on the outside too. The bellows leak is visible as a point of light on the inside bottom of the bellows using a light from the outside reflecting off the inside of the door. I have ordered some fabric paint to try to solve that but would be willing to buy an Agfa bellows if was not a waste of money due to incompatibility. As you can see from the photo, the images are pretty nice otherwise, so I would like to fix this. I do have another Spark that is less leaky, so if I can’t fix this I can still enjoy the Iskra experience.
Thank you WoodallP, that is encouraging. The link below is just one of several from China offering Agfa bellows, and they sure look like they might work. Also good to hear that it can be done by a person of reasonable skill, though I am not sure I would want to try to make a bellows. I also have the other vertical bar light leak to fix. Since I don’t do my own developing test rolls can get expensive.
