Mechanical XPAN, is it possible?
Long in the tooth but still extremely capable and available for a song (relatively) at this point.
Yes, you can crop any film or digital to panoramic but I find it better to compose if I see the aspect ratio while shooting. When I shot panoramic without built in panoramic ARs I was more sloppy with my framing since I knew I was just going to be cropping in post.
Easy enough to sketch the format on mylar or similar and place it over the groundglass on bigger format cameras.
Here's my mechanical Xpan. Canon 7 body hacked to 63mm frame. Modded for continuous advance, two strokes needed via stop for correct spacing. Fuji 45mm f5.6 lens (from GS645W) on Kodak/Compur shutter and recycled helicoid. RF modified to couple the lens.
Canon 7 Panoramic mod by Olivier, on Flickr
Canon 7 pano mod by Olivier, on Flickr
That’s very impressive! Would you be willing to share more details?
Well it starts with a Canon 7 body, a GS645W (lens), a Kodak Retina I (shutter) and Hoya 28mm lens (helicoid).
Remove the focal plane shutter and other bits and hacksaw the film gate. Plug all holes; without the shutter light leaks are an issue. Transfer the lens to the mechanical shutter and check the approximate back focus. Dismantle the donor lens and fit the lens/shutter via 3D-printed parts. Body and donor lens needed machining on a lathe to make everything fit and it took a few tries to get the lens at the right distance for infinity focus (checked via pseudo auto-collimator). Let's just say 0.5mm is a LOT for a wide lens.
For the RF I replaced the arm for the cam follower with slightly shorter, 3D-printed one (some math involved), and screwed a cam of sort (also 3D-printed) on the back of the lens to contact the cam follower. For the film advance, by chance I found that by raising slightly the plate which is actuated by the rewind toggle (under the bottom plate) it would allow for continuous winding. So I bolted a stop for the half pano frame.
Ah, that’s really helpful, many thanks. Unfortunately you mention two technologiesI don’t have: a lathe, and a 3D printer. I’m sure I could learn the skills (eventually), but I don’t have the kit.
But I am extremely impressed by what you’ve done.
