Just noticed this, I think you are right! Maybe the top got damaged at some point and someone replaced it with a Fed/Zorki one. Still the engraving looks not done too badly considering the quality of other Leica copies out thereThere’s no little step where the viewfinder is, which makes me think it could be based on a Soviet copy.
I missed this in the first picture. The viewfinder frame does indeed look Russian but the viewfinder/rangefinder bezels look Leitz.There’s no little step where the viewfinder is, which makes me think it could be based on a Soviet copy.
Is it still Leica I size? I notice the blanking plate for the slow speeds which suggests a real IIf body but the rangefinder/viewfinder arrangement is clearly the II/III/IIIa version. I don’t know much about conversions so maybe I’m missing something obvious.Got a nice Leica I from 1930 converted to IIf in 1952, according to Leica records. No other details available from the company records. It needs work, the shutter switch is slowly returns to normal position after firing the shutter.
It is definitely IIF size case with nickel parts from I. Same size as my chrome IIf from 1955 and it has rangefinder magnification.Is it still Leica I size? I notice the blanking plate for the slow speeds which suggests a real IIf body but the rangefinder/viewfinder arrangement is clearly the II/III/IIIa version. I don’t know much about conversions so maybe I’m missing something obvious.
I have a black II from 1932 with a 1.5x dioptre which couldn’t be original. Leica’s only record has it going back to the factory in 1958 so I suppose that is when it was done but if so it is strange it didn't get the same treatment (it apparently got a lovely new bottom plate however).
Thanks for the suggestion, I didn’t know these but it seems they were mainly used in the US. I looked them up and landed on:Are they not ASA flash connections?
Hi, I totally agree, but the number 149044 puts it in the 1935 chrome batch from 148951 to 149350 which confuses me. I haven’t written to Leica about this one as I try to space my requests. It came with an unnumbered 7 o’cock nickel 50mm lens but who knows if that is original. Both have “O”. To me it looks original black but pretty battered!I can't double check your serial number but it looks like it is black with nickel knobs and correct Woods metal style lettering. This really doesn't look like a conversion from chrome to me.
