Leica LTM Leica Screw Mount Conversions - Show Yours
Regarding the flash connectors, I have a Nicca 3S which has an identical pair of connections on the front in the same position.
I believe one is for electronic flash and the other for old style bulbs that needed to reach peak output before opening the shutter.
Looks likely that someone modified the camera to flash sync in a similar way. Leicas have the little dial under their shutter speed to set delay on later Barnacks so only need a single connector on back.
The camera above is a post war conversion. Most post war conversions have the rangefinder of the Leica lll, much better than the rangefinder of the Leica ll because it is life-size.
gelatin silver print (summar 50mm f2) leica lll
Amsterdam, 2022
Sometimes the synch causes shutter problems. Did you try yours?
What kind of problems do you mean? Yes, I tried it already. It is working almost great. The issue I still have - shutter button not returns to normal position after firing. Planning to disassemble the shutter once I receive new curtains.
