A Leica Lover’s Guide to Acquiring a Digital M:
The best model for you depends on your priorities and pocketbook!
by Jason Schneider
When did digital imaging supplant film as the primary image capture medium? There’s no definitive answer to that question, but it happened a lot sooner and faster than many imaging experts had predicted. By the mid to late 1990s the process was well underway in newsrooms and other venues where fast turnaround is essential. And by about 2004 digital had clearly overtaken analog overall, and many photographers were swiftly dumping their fancy film cameras (other than Leicas and twin-lens Rolleiflexes) at giveaway prices.
Meanwhile Leica aficionados were anxiously awaiting the long-rumored digital Leica M, the camera that would triumphantly transition the world’s greatest rangefinder camera into the digital realm, and blow everything else into the weeds. What arrived in 2004 was the world’s first digital rangefinder camera, and gallingly, it even had an M-mount, but alas, it wasn’t a Leica—it was the Epson R-D1! Built by Cosina in collaboration with Seiko, and based on the Cosina-made Voigtlander Bessa R-series film cameras, it sported a 6.1MP APS-C-format CCD sensor (which gives a 1.5x crop factor) has a large, bright 1:1 range/viewfinder with user-selected, projected, parallax compensating frame lines for 28mm, 35mm and 50mm lenses, sensitivity settings from ISO 200-1600, shutter speeds from 1-1/2000 sec plus B, traditional analog dials, and a dinky 2-inch 235k-Dot LCD. Its imaging performance was commendable at the time, and it created a sensation. Lamentably, it could only take SD cards up to 2GB, its initial selling price was a hefty $2,999.00, and sales did not meet expectations. Result: The landmark R-D1was discontinued in 2007 after a 3-year production run.
Leica M8 black, front view, with 50mm f:1.4 Summilux-M ASPH. lens..jpeg
Leica M8 black, front view, with 50mm f/1.4 Summilux-M ASPH. lens.
In 2006, Leica enthusiasts’ dreams of a digital Leica M were finally fulfilled with the release of the Leica M8, the first digital Leica M. Based on the late lamented Leica M7, then the only 35mm Leica M to incorporate TTL aperture-priority autoexposure that works with most M-mount lenses, the M8 was designed to deliver a shooting experience similar to the M7. It combined the new digital technology with traditional manual focusing and viewing via the superlative multi-frame Leica M range/viewfinder showing frame line pairs of 24mm and 35mm, 28mm and 90mm, or 50mm and 75mm. It featured a Kodak-made APS-H-size (27 x 18mm) 10.3MP CCD image sensor with a 1.33x crop factor, a modern menu system, sensitivity settings of ISO 160-2500, RAW DNG plus Fine or Standard jpeg file formats, a 2.5-inch 230k-Dot LCD, stepless aperture priority shutter speeds from 32-1/8000 sec plus B, and USB 2.0 connectivity. The M8 body measures 5.47 x 3.15 x 1.46 inches (slightly larger than analog Leica M’s) and weighs in at 20.85 ounces with 3.7v rechargeable lithium-ion battery. The Leica M8 body was initially priced at about 4,200 euros ($4,461.66) when it was released on14 September 2006. That is equivalent to a whopping $6,960.19 in 2024 dollars!
Despite its relatively low-tech specs compared to Leica’s later Digital M offerings, the M8 is satisfying to use, can capture compelling images with a “chrome film” feel, and has gained a small but devoted following in recent years. Here’s a rundown of its pros and cons:
PROS:
  • In 2024 the Leica M8 is the least expensive digital Leica M you can buy, although prices on the used market have steadily crept up. The current asking price range for clean fully functional Leica M8 bodies on the leading online auction sites is $1,800.00 to $2,800.00, with the majority falling between $2,300.00 and $2,500.00.
  • CCD sensor captures images with “presence,” clarity, and a “chrome” look reminiscent of slide film. While CCD sensors have some notable disadvantages and have largely been supplanted by BSI CMOS sensors, they can capture a distinctive rendition that many find appealing.
  • Excellent performance for black-and-white imaging. The CCD sensor in the M8 lacks an anti-aliasing (AA) filter and that may explain why the camera can capture superlative black-and-white images. Indeed, some have dubbed it “The Poor Man’s Monochrom.”
  • The M8 is fully compatible with a wide array of M-mount lenses, not only those made by Leica, but also superb and interesting M-mount lenses by Zeiss, Voigtlander, 7 Artisans, etc. It will also accept a wealth of vintage M-adapted screw mount lenses by Canon, Nikon, and zillions of USSR and Russian-made lenses.
  • The 1.33x crop factor of the M8’s APS-H sensor can be advantageous in portraiture and street photography, providing a little extra reach and possibly a more attractive perspective.
CONS:
  • The Leica M8 is nearly 20 years old, and while most of them have held up relatively well, they’re more likely to require repairs or servicing than newer models, and some spare parts are no longer available.
  • The M8’s CCD sensor has limitations. While it can capture vibrant images, it does not perform well at higher ISOs. Its practical sensitivity setting limit is ISO 640, and it works best at ISO settings of 400 and lower. At higher ISOs noise is excessive and occasionally banding in the images is observable.
  • Since the sensitivity of the CCD sensor in the M8 peaks in the near infrared, its color rendition is not perfectly accurate. Due to this and its lack of an AA filter, false colors can occur with dark fabrics, especially those made of polyester materials, resulting in a purplish or brownish cast in images shot with the M8. At the time Leica responded by offering a free IR filter to M8 owners, which was effective, but is no longer free! Other than that, the M8 was favored by many for its intense color rendition.
  • The 1.33x crop factor of the M8’s APS-H-format sensor can be a negative feature for wide-angle lovers—a 35mm lens becomes, in affect a 46.6mm normal, a 28mm becomes a 37.4mm semi-wide-angle, and perhaps worst of all, a 21mm ultra-wide-angle is equivalent to an “ordinary” 28mm.
The Leica M8.2
In 2008, Leica unveiled the Leica M8.2, a variant of the M8 with a somewhat quieter shutter, a sapphire glass on the LCD for better abrasion and scratch resistance, a top shutter speed of 1/4000 sec (down from 1/8000 sec) and a flash sync speed of 1/180 sec (down from 1/250 sec). The modified shutter runs slightly slower, thus generating less noise and vibration. Other changes: a separate simplified “snapshot” shutter setting, an Auto-ISO function on the menu that ups the ISO setting if proper exposure cannot be achieved at the slowest useable shutter speed and flashes a warning in the finder, and has a ‘discreet” setting that allows wind-on noise to be delayed by holding down the shutter release. The Leica M8.2 was available in silver chrome and black finish and is identifiable by an “M8.2” engraved on the accessory shoe. The Leica M8.2 was discontinued in 2009, with the release of the full-frame digital M9.
Leica M8.2 in black with 50mm f:0.95 Noctilux-M ASPH. lens..jpg
Leica M8.2 in black with 50mm f/0.95 Noctilux-M ASPH. lens.
Less commonly offered online than the M8, the Leica M8.2 generally fetches from $2,500.00 to $3,200.00 on the leading online auction sites or from Leica specialist dealers.
CONS:
The Leica M9: A full-frame digital M at last!
Released in 2009 and in production (3 versions, including the Leica M9-P and Leica M-E) until 2012, the first full-frame iteration of the Leica M was a great success, with a total production of 51,400 units. Incorporating an upgraded 24 x 36mm 18MP CMOS sensor that maintains the inherent angular coverage of any mounted M-mount lens, the M9 incorporates many other improvements, including the ability to enter details of non-coded lenses manually, assigning one of the quick access buttons for manual ISO setting, an Auto ISO function that ups the ISO to prevent underexposures, and a “pull” option that provides an ISO 80 setting (the normal range is ISO 160 to ISO 2500).
Leica M9, black paint finish with 50mm f:1.4 Summilux-M ASPH. lens.jpg
Leica M9, black paint finish with 50mm f/1.4 Summilux-M ASPH. lens
The Leica M9 employs the same basic shutter as the M8.2, but the “S” (snapshot) setting has been moved to the user profiles menu, and the extra space on the shutter speed dial has been used for an 8 sec speed, expanding the shutter speed range from 8 sec to 1/4000 plus B. The main menu also includes a “soft” setting (in addition to the M8.2’s “discreet” shutter setting) that fires the shutter without going through the “pressure point” for the AE lock, resulting in a smoother release. The TTL exposure system reads off one white and two gray shutter blades, a system designed to enhance overall metering accuracy. In the large, bright viewfinder the projected, parallax-compensating frame line pairs have reverted to the traditional 28/90, 35/135, and 50/75 so lenses wider than 28mm require a separate shoe-mount finder. The viewfinder magnification remains at 0.68x. A comprehensive bracketing feature is available and accessed via the “set” button on the back of the camera. The small window that showed exposures remaining and battery status on the M8.2 has been removed—the info is now accessed via the LCD by pressing the “info” button. Finally, there’s now a slight “step” on the side of the body next to the main viewfinder window, a cosmetic enhancement to the M9’s attractive form factor.
PROS & CONS
PROS:
  • The M9’s 18MP full frame CCD sensor is fitted with a UV/IR cover glass that largely eliminates the need to use lens-mounted IR and UV filters, to minimize color casts when photographing certain synthetic fabrics, as required with the Leica M8/8.2. However, this is not an anti-aliasing (AA) filter so full sensor resolution is retained. This enables the M9 to capture vibrant images with astonishing detail at low ISOs.
  • A one-stop improvement in noise at any given ISO compared to the M8/8.2. The M9 sensor uses CFA dye for improved red sensitivity, signal paths in the output stage have been shortened for greater efficiency and speed (a new PCB design), two processors are now used for improved jpeg quality and speed, and entirely new firmware helps to reduce noise and enhance imaging performance.
  • A new microlens array has increased offset at the corners to minimize the effects of shading, and there’s no limit on the lenses that can be used (even short back focus ultra-wide-angle primes) or the 16/18/21mm Tri-Elmar M.
  • Excellent ergonomics overall. Most settings are intuitive and logically arrayed, resulting in a swift learning curve and excellent responsiveness in applications like street shooting, one of Leica’s traditional specialties.
  • The Leica M9 was subject to “sensor corrosion,” where the sensor glass within the camera can oxidize or develop white spots, significantly impacting image quality. This is largely due to the unique design of the M9 sensor which lacks a protective coating on the sensor glass, making it subject to environmental factors such as moisture and high humidity.
  • The M9’s sensor performs admirably within its design parameters, but it isn’t a match for current CMOS sensors in low light. It performs admirably up to ISO 800 and is useable but noisy at ISO 1600.
  • The body of the M9 is only marginally thicker than analog Leicas and the M10, but it feels (and looks) fatter, and this adversely affects handing for some users.
  • The M9’s LCD is not up to the same standard as its superb low ISO imaging performance. Many reviewers have panned its low resolution, limited viewing angles, and slow refresh rate, making it difficult to assess images, especially in low light, and compared to later Leica M models.
The Leica M9 is available in silver gray or black enamel. The black model is covered in simulated vulcanite; the silver-gray model is clad a smoother textured covering. The M9 is readily available, body only, in clean fully functional condition at prices ranging from $2,100.00 to $3,900.00 from Leica specialist dealers or on the leading online auctions, with most falling in the $3,000.00 to $3,500.00 asking price range.
The Leica M9-P: In 2011 to 2012 Leica produced a slightly upgraded iteration of the M9 dubbed the M9-P featuring a tougher, more abrasion resistant LCD with a sapphire glass top surface. Both the black paint version (code 10703) and the silver-chrome version (code 10716) are covered in synthetic vulcanite. There is no ‘M9’ logo or Leica red dot on the front, and the top plate is engraved with the classic Leica script and ‘Leica Camera AG Germany’ logos. The Leica M9-P model name is engraved on the hot shoe,
The Leica M9-P is less commonly seen on the used market than the M9, and often commands a slightly higher price. Current range for bodies in clean working condition: $3,200.00 to $3,800.00. Note: The Leica M9, M9-P, and M-E are frequently offered with replacement sensors due to the previously mentioned corrosion problem, generally a plus for potential buyers.
The Leica M-E (Typ 220): In production from 2012 to 2015, it was intended to be an entry level or ‘economy’ version of the M9. The sole functional difference is the absence of a frame line preview lever. In addition, the top plate and base of the camera are painted anthracite gray, and the faux-leather covering is claimed to provide enhanced grippiness for more secure handholding. Finally, the shutter speed dial, shutter release, on/off switch, and accessory shoe are finished in silver-chrome.
The Leica M-E is less commonly listed on online auctions than the Leica M9, but it is not rare. Typical price range for clean, fully functional bodies: $2,500.00 to $3,200.00.
The Leica M240: First Digital M with a full frame CMOS sensor
Introduced at Photokina in 2012, it remained in the line until 2017, am impressive run for a digital camera. A total of about 58,000 units were turned out, a mark of its marketplace success. The M240’s 24 x 36mm 24MP CMOS sensor, designed by CMOSIS of Belgium and manufactured in France by ST Microelectronics, delivers significantly improved imaging performance at high ISOs compared to the M9. The electronically upgraded M240 also added a new (for Leica) live-view function, with zooming and highly magnified focus peaking, on a much improved 3.0-inch 920k-Dot TFT Color LCD, with a Gorilla glass cover or via an optional compact shoe-mount EVF-2 Visoflex viewfinder attachment. This versatile accessory greatly facilitates composing and focusing the image with the full range M-mount lenses, with an even wider range of Leica R-mount lenses and third-party lenses, and with virtually any close-up device. The M240 was also the first Leica M with Full HD (1920 x 1080p) video with sound at 25fps, and a full-res maximum framing rate of 3 fps. Many marketing experts saw the M240 as an attempt by Leica to spark renewed interest in the Leica M after the slow rollout of the M8, M8.2, and M9.
Leica M240 body: First digital Leica M with a full frame CMOS sensor was very successful, had a 5-year production run.
The M 240’s range/viewfinder continues the classic pattern of its immediate predecessors (28 + 90mm, 35 +135mm, or 50- 75mm) and they are mechanically actuated but are now LED-illuminated in a choice if white or red for greater visibility in low light. As with the M8.2 and M9, the dimensions if the frame lines are matched to the lens coverage at a focusing distance of 2 meters.
The M240 body feels “chunkier” than the M9 due to its slightly increased body thickness, and the presence of a contoured thumb rest, and it’s heavier because of its larger Li-ion battery, which provides an impressive 1,700 to 2,100 shots per charge. Due to the deletion of the no longer needed frame line illumination window, the size of the Leica red dot and the black ‘M” on the front of the camera were enlarged to enhance the camera’s esthetics. The standard finishes are black enamel (code 10770) and silver chrome (code 10771), both covered in simulated vulcanite.
PROS & CONS
PROS:
  • A used Leica M240 is less than half the price of a used Leica M10 or a new M11, which can run $5K to $9K.
  • Proven reliability: The M240 has an enviable track record as a reliable camera, and if any repairs are required, they can generally be performed expeditiously, which is not always the case with the M11.
  • For typical users (who print out their best images and/or view them on a computer screen) the M240 is functionally akin to later digital M’s, providing much the same shooting experience.
  • With its 24MP sensor the M240 can process files more quickly than a camera with a 50+MP sensor and is well within the working capacity of many older computers.
  • There are many situations (such as urban street shooting in dicey neighborhoods) where you might not want to walk around with an $8,000-$9,000 camera and the M240 presents less of a financial risk.
CONS:
  • The M240 is old for a digital camera and more likely to require repairs and servicing, neither of which is cheap.
  • The M240 is marginally larger than other digital M’s. It only comes to a few millimeters here and there and many users have no complaints, but some feel it’s too “fat” and that that adversely affects its handing and feel. Its large capacity Li-ion battery also makes it heavier than other digital Leica M’s.
  • Its high ISO performance is limited to about ISO 6400, and “digital grain” and other defects are observable at higher ISOs. Indeed, sticklers and pixel peepers generally stick to ISOs of 3200 and lower.
  • Shadow banding: you can occasionally get banding effects in the shadows in images shot with the M240. Solution: make sure your exposure is on the nose, and if it is, drop the shadows and the banding will almost always go away.
I'll just add in the following, which may be of some note... since buying an M240, there's been multiple times where I've actually forgotten it's a digital camera and left it "on" for days on end. A quick tap of the shutter button gets it ready to go in a surprisingly quick amount of time, and the battery rarely needs charging or changing, despite my complete carelessness with the off switch.
The various Fuji X bodies I've used for the last eight years were close to feeling like a film camera, but there was always something a bit too digital about them, if that makes sense. The M240 is the first camera I've used where I can actively forget I'm recording things to an SD card or relying on a battery, and I like that.
No cocking with digital (except Epson one).
The cocking is replaced by turning switch power on and disabling auto power off.
This will eat battery.
With my M-E 220, I have sleeping mode enabled within one minute.
If camera is in M mode, here is no lag.
If it is in aperture priority, it take sometime to wake up and measure exposure.
But honestly, no digital camera is as fast to take exposure with confidence and predictable result as film M without useless electronics. Maybe I should use my digital M in M mode more often, I'm just lazy to do S16 with digital.
Goodness. After 12 years time for me to re-RTFM. I don’t know how I’ve set mine up for power save.
Yup, the only times I've gotten burned is if it's in a bag with the power on and resting so that the shutter is depressed enough to trigger the meter. That drains the batter fast enough!
I think in the future, much like everything when the high cost/scarcity for original will allow for competing lower cost rangefinder alternatives. Welcome to era of digital rangefinder clones...or Leica will saturate the market with 2nds and rerelease 'classics' lol
I wish, but given the mechanical precision needed to make an optical rangefinder work with interchangeable lenses (with a typical RF base length, the prism swing needed to cover the range of infinity to 1 meter is less than 3 degrees!) I doubt if digital rangefinder clones will EVER be price comparable with EVF alternatives. When I bought my R-D1 in 2004, plenty of people were eager to tell me I was an idiot for spending US$3000 for a camera that was much less capable than DSLR alternatives X, Y, or Z, and they probably were right (although 20 years later, I still enjoy using my R-D1 occasionally; I wonder what X, Y and Z are doing?)
While technology can help offset some of the cost of all that mechanical precision, I doubt if much cost can ever be pushed out of that pricey VF/RF module. Feisty little Pixii SaS of France is trying as hard as anyone can to make a modern digital rangefinder camera that doesn't need to be sold at the luxury end of the price scale, and if your idea of "classic gear" is something that says Hewlett-Packard, Tektronix, or Collins Radio on the nameplate instead of Leica or Contax, you may find a Pixii Plus or the new Pixii Max is right up your alley (as I do.) But under the Pixii's top-panel OLED display is still a lot of tiny, high-precision opto-mechanical rangefinder wizardry that's always going to be unavoidably costly...
Tell me how you like your Max. I have to send my A2572 off for upgrade.
In all honesty, unless you're very dogmatic about the virtues of the 36x24mm (Simplex) format, my take is that the Pixii Plus (A2572+) is still a highly persuasive camera. The bodies are the same (except that the Max now has a hinged battery door instead of a removable cover; it wouldn't surprise me if the Plus also gets this eventually.) The software version is the same, the controls and menus are the same, and I can't really see any image quality differences between the two sensors. (Maybe that's just me.)
Other than the sensor, the biggest change in the Max is the range/viewfinder. It's effective but has one potential limitation, especially if you wear glasses (which I do.) To fit in a 54-degree/35mm viewfinder frame while keeping the same 0.67x magnification and without enlarging the finder module (which would have made it impossible to update older cameras) Pixii used higher-refractive-index elements in the finder optics to make the finder's edges more usable. It works, but the 35mm frameline is far enough out toward the edge that glasses-wearers will have to scan a bit to see all of it. It's not as extreme as a Canon P, for example, but it's definitely a bit of a stretch. The 50mm frame also is trimmed a bit to share space with the exposure-confirmation dot. The 40mm and 75/90mm frames are nicely defined; if I were starting over, I might pick one of Cosina's 40mm Voigtlander lenses as a normal lens for my Pixii Max. Selecting 28mm simply turns the frame lines off and you just use the full area of the finder for composing; this actually works very well for street/spontaneous shooting, which is how I normally use a 28mm lens anyway.
Sorry to hijack the thread! We now return you to Professor Schneider's topic...
