Okay, since this has devolved into a circular argument, I decided to go back to the beginning to try and give my answer to the original post.
I don't like one medium over the other, except when the technical abilities of one or the other call for using that medium at that time. I like them both and use both with the mindset that I am after the best image I can get from the situation. Having used film only for many decades one would think I'd be biased towards that way more than digital, but oh contraire, mon ami.
It's the same arguments that have been dredged up over the years over what film format is the best, whether or not b&w is better than color, which camera/lens is the best. It's no different than declaring that watercolor painting is far superior to acrylics, or that stone is better than wood for sculpting. If you are satisfied with the finished image portraying what your vision was when you decided to make/capture it, then there is no reason to doubt that the way you produced that image is somehow deficient. In the end, it is all in the eyes of the beholder whether it holds up to scrutiny or not. All the great artists over the centuries have had their fair share of detractors. Some worked in only one medium, while others used multiple methods of creation to convey their imagery to the public. And yet, they still had to suffer the slings and arrows of criticism.
I say it doesn't matter how you got to where you did in your journey to present your vision to the masses, unless I want to find out how you did it so I can emulate it.
PF
