Keith
My opinion would be that if you can afford to buy a dedicated monochrome camera do it for the emotional reasons and keep logic and physics out of it. Life is too short to vacillate over such things! 🙂
Thanks Keith (long time, ‘eh?)My opinion would be that if you can afford to buy a dedicated monochrome camera do it for the emotional reasons and keep logic and physics out of it. Life is too short to vacillate over such things! 🙂
I’m not vacillating - at least not yet. That’s because I’m yet to receive the funds 😂
For now, I’m just pushing ideas around and letting them stew in my head. Maybe they’ll be cooked by the time the funds arrive 🤞
…Mike
That's something I certainly have in the mix of "things I might do" when I think on actually executing this "not yet a plan"...You could always split the $... buy two things. The Pentax K3 Monochrome goes for $2199 and you can buy a few awesome (and small) lenses for less than $500 each.
Thanks for reinforcing the idea of the Pentax SLR. I've been looking at what I actually do when doing post-processing on photos originally taken, quite deliberately, with the intention of converting them to B&W later. I've been doing that over the last couple of days and paying attention to how that processing has gone. To a surprising (to me) extent, I'm working the mix of colours I use to get just the conversion I want to emphasise some parts of the photo and de-emphasise others.The K-3 iii M is a good choice, with the proviso that to get along with the K-3 iii M you need to like SLRs and be willing to engage with a (potentially new) complicated user interface. I bought (so far!) the 15, 21, 35 and 70mm HD Pentax Limiteds for much less than the cost of one used Leica lens. The design approach and performance aims are different to Leica, but I like them a lot, particularly the 35 and 70mms.
Oh, and that you can get one. I gather they are very thin on the ground.
And (draw breath) given your ‘shaken, so blurred’, you’ll find that the implementation of vibration reduction in the Pentax really helps for hand held photography. You can photograph anything you can see (which is less than with the Leica . . . ).
L1005046_100crop by fiftyonepointsix, on Flickr
G5046_100crop by fiftyonepointsix, on FlickrI’m not sure I get all of that (I’ll have to think about “spatial conversion artefacts” some more 🤔) but at least I get most of it. From some of my reading, I’m getting that protecting highlights is key with pure-mono digital - which, I’m guessing, can run hard into “expose to the right”😱First-Hand Knowledge: it is easier to recover highlights from a color camera when converting to monochrome. Typically one or two channels saturate, not all three. So- when converting to Monochrome, and doing an interpolation of the RGB channels- you essentially get a higher saturation count. I wrote my own monochrome conversion algorithms for the M8 and M9. You still get spatial conversion artifacts. Which I hate- so I have the M Monochrom and the M8 and M9. I wanted to see how far I could push the conversion process.
chimney_m9_converted by fiftyonepointsix, on Flickr
chimney_monochrom by fiftyonepointsix, on Flickr
Mt_Vernon_35Ultron_NoSharp_Simulated_RED by fiftyonepointsix, on FlickrFirst-Hand Knowledge: it is easier to recover highlights from a color camera when converting to monochrome. Typically one or two channels saturate, not all three. So- when converting to Monochrome, and doing an interpolation of the RGB channels- you essentially get a higher saturation count. I wrote my own monochrome conversion algorithms for the M8 and M9. You still get spatial conversion artifacts. Which I hate- so I have the M Monochrom and the M8 and M9. I wanted to see how far I could push the conversion process.
I understand, but its manifestations under shadow manipulation are weirdly inconsistently apparent. I have a Kodak 760m, it still even works and I can still get batteries for it that work.The Type 246 Monochrome used 12-bit values, as did the Kodak 760m. Kodak had the same problem with banding.
Leica chose to clip the low-order 2 bits of the image, the original M Monochrom is 14-bits. That makes a big difference in monochrome images as they are not interpolated.
GAMMA by fiftyonepointsix, on FlickrI have always been inclined to think "camera bodies come and go, but lenses are forever". So it's probably what I'll be doing if I decide not to proceed down the "monochrome only camera" path.My two cents: Whenever the cash arrives on your doorstep, focus not on cameras but on lenses. Cheers, OtL.
The highlight weighted metering in the M11M retains detail in everything apart from specular highlights. The MM, Typ 246 and M10M have, well, simpler, metering, to put it kindly. The Pentax K-3 iii M metering preserves highlights really well.
