Tele Rollei + Rolleinar question
Patarei
6:59 PM
Sweden
I just bought a Tele Rolleiflex, and also bough a Rolleinar 0.7 + a Rolleinar 1 for bay 3.
A stupid question maybe, but can I use the Rolleinar 1 without the Rolleinar 0.7 and which range in cm do I get?
I am sad one spends so much and the Mamiya Twin lens cameras do all this with built in bellows.
I used them professionally for over 20 years. way more reliable than hazzelbloods..
The site has it all listed correctly? I am not sure what the confusion is.
The listing below - taken from the link @KoNickon posted lists out the ranges of the "Standard" Rolleinars when attached to the listed swing-out Rolleinar base. That's what was asked, no? Or was this about the Rolleinar alone?
Rolleinar 0.35: 110-53.1“ / 280-135 cm
+ Rolleinar 1: 30.3-24.4“ / 77-62 cm
+ Rolleinar 2: 18.1-15.7”/ 46-40 cm
+ Rolleinar 3: 13.0-11.8“ / 33-30 cm
Rolleinar 0.7: 54.3-36.6“ / 138-93 cm
+ Rolleinar 1: 24.4-20.5“ / 62-52 cm
+ Rolleinar 2: 15.7-14.2“ / 40-36 cm
+ Rolleinar 3: 11.8-11.0” / 30-28 cm
As an owner of the Tele-Rolleiflex myself, I basically never use anything but the Rolleinar 0.35 on mine. 135cm is plenty close (near full head-shot) and I'd rather not deal with the potential parallax issues, which are likely to crop up if you stack Rolleinars like that.
Edit: Re-reading your question you are asking about using the Rolleinar 1 without anything else on the Tele Rolleiflex. Of course that's possible, but I am not sure where you'd end up with the parallax correction.
Anyway the distance I get on my Tele Rolleiflex + a Rolleinar 1 and nothing else is about 120cm to 60cm from infinity to close focus. These are not measured - I was just eyeballing it.
Yes my question was about the Rolleinar 1 alone.
Well, I might try it out. Otherwise I stick with the Rolleinar 0.7.
Thank you for your reply.
