gavinlg
What if I told you guys I did a little cheeky comparison between a zuiko 28mm f2.8 on my ZF and a Zeiss biogon 28mm f2.8 on a Leica M10.....
....and the Zuiko is at least as good, if not better in pretty much all metrics.
Darinwc
Preaching to the choir here. But that is one lens I dont have. I heard the Pentax 28mm f3.5 was better than the Olympus 28mm f3.5. But then the Oly 2.8 is supposed to be better than the 3.5. IDk just rambling. Guess I should look for a 28mm f2.8!
p.giannakis
Pan Giannakis
I have both - both nice lenses. When I used to have plenty of free time, I was writing up things like this:Preaching to the choir here. But that is one lens I dont have. I heard the Pentax 28mm f3.5 was better than the Olympus 28mm f3.5. But then the Oly 2.8 is supposed to be better than the 3.5. IDk just rambling. Guess I should look for a 28mm f2.8!
Ljós
Well, I will follow your findings regarding the optical merits of the lil' 2.8 28mm versus the Zeiss with interest. I managed to snag a clean, late copy of the f2 28mm Zuiko recently and am in the process of evaluating it. Should be great – but I could see myself getting a 2.8 or 3.5 as walkabout or hiking or having-a-yellow-filter-attached-28mm in addition. Also incoming: a clean, late version of the 50mm Macro 3.5, and a late version of the 35 f2.8. (And here my spree will end. For the time being ;-))
Freakscene
Obscure member
The 25mm is the standout ZM, most reviews of the 28mm comment that itis substantially less good than the 25mm.
Did you test for flare and ghosting?
