NYC Journal
Status
Not open for further replies.
Cal, have you tried wearing some good moisture wicking clothing while sleeping? I've found that it really helps regulate my body temperature while sleeping. I may look like I'm going on a ride or rock climbing, but I'm really comfy.
Speaking of ride, yesterday I finished the A.S. Gillott.
I may cross post from bike forums, or you could read the saga here. Last page is the most recent update, of course.
This is a fantastic riding light touring bike.
Phil
Lots of OCD thinking. LOL.
Cal
Thanks for the praise!
I wouldn't call it OCD but I'd definitely describe it as obsessive thinking. No compulsion or ritualization to complete the diagnosis, nor did my obsessive thinking affect my life or work on a negative way.
That front wheel went through maybe 5 iterations until I settled on a steel Brampton hub with cones donated from different Sturmey Archer front hubs. That wheel build drove me nuts for a while then I just gave up on it for about 3 months.
Next up is to complete the Frejus, but a part of that is to build a new rear wheel for the Miyata 610 as the wheel which it currently rolls on is a Campy Record hub with Mavic MA2 rim, which will eventually go on the Frejus as built. So I'm going to find a matching front Record hub and finish the wheel set. After that, it's little things and shuffling bike parts like tiles in a game. It will all settle down to exactly where parts belong.
Phil
I got a chance to install the dozen guitar hangers today. Eleven guitars hang from one wall in two staggered rows: six along the top; and 5 along the bottom.
The install was easy into a plaster wall. Mucho strong.
Rearranged some things in the room but it is very impressive. “OCD is good,” I say.
Cal
Phil,
I’m kinda doing the same shuffling and weighing possibilities.
I have a black White Industries ENO elliptical hub. I happen to have both spacers for 130 and 135 mm.
The Ti IBIS Mountain Trials makes a great single speed. With a 46-17T I get a 63.59 inch gear with a perfect chain.
Thinking of having a single speed option on another bike. One logic is to make a rear wheel for the IBIS SS since I have a period correct and matching retro Mavic rim salvaged with the right spoke count (32) that had a Ringle hub that failed.
The IBIS SS has wonderful Suntour 7-speed XC Pro, motorcycle style brake levers, grease guard, and a Peterson SE rear brake. The bike is kinda OEM original and is a kinda garage find. The idea here is to use the bike as a single speed and save the OEM drivetrain from wear and tare.
I secured a 32 hole Wobler Profile 18 rim (700C) that matches my racing wheels from back in the day. My Ti Basso is a rebranded Litespeed Classic, but with a bead blasted frame that has a blue fade that was clear coated by Rainbow Cyclery. The idea here would be a perhaps 15 pound single speed.
This bike has Dura-Ace with XTR first gen shifters along with a straight Ti handlebar, 12-26T with a 53/39 chainrings.
Next up is just build a pair of 26 inch wheels. I also have on hand a Suntour XC Pro Grease Guard front hub (32-hole) and a pair of polished Sun/Ringle welded rims. Know that I have an IBIS Alibi 15 1/2 inch frame on hand, so I could build it out as a single speed or a 3x1 or 2x1 (have on hand a Paul’s Melvin).
All three are cool ideas…
Hmmm…
Cal
More obsessive thinking involving bikes: My Fat Chance Yo Eddy is a mix of parts that Fat Chance had on hand when they were close to shutting down. I have XTR brakes, XTR right brake lever, but XT derailleurs, early XT shifter/brake lever, and a compact drive 42/32/22.
The good is that being a later frame made in Saratoga New York, it features a standard bottom bracket instead of the pressed in bearings.
So I have stockpiled a Dura-Ace 9 speed with mucho cassettes, especially 12-25T including spare Ti clusters, as well as other cassettes. So I’m thinking of doing a Compact Drive with a set of 42/32/20 chain rings I have on hand.
Then again I could upgrade my Ti Basso road bike to 9-speed.
Another option would be take the first gen XTR 8-speed shifters off the road bike and use them on the Yo Eddy, but then I have to deal with canti-brakes instead of V-brakes.
Because of the Yo Betty (Maggie’s bike) I have a stockpile of 9-speed XT cassettes thanks to Phil’s advice. Maggie is pushing 72, and it is not likely that this resource will get utilized, meaning a stockpile of cassettes.
Easiest solution though is just go 2x11 XTR since I have all that on hand, and mucho-mucho XT 11-speed cassettes.
Hmmm…
Cal
A sunny mild day with cool temps, a good day to kill Knotweed in the dead-end and my neighbor’s property (abandoned house).
The Dow was up 1000 points on some tariff agreements. Was interesting to expand the charts. People who panicked and sold lost money.
Gold dropped to the low $3.2K range, but oil prices are in the $62.XX range.
Cal
This is the 5th year of battling Knotweed, and by now the Knotweed is very weakened. Large stalks taller than me I can pull out of the ground with the root and all. My neighbor’s property is mostly shaded by trees, and since I have to avoid the sun it worked out well.
Still have to pull Knotweed by the marsh on my dead-end neighbor’s property, but the ground is softer there and it is easier going.
I think I will expand my war on Knotweed and use my 7-8 inch Milwaukee chainsaw to cut-cut-cut by Dickey Brook. I’ll start weakening the thicket there. The chainsaw is easy work and will take only a few minutes. The stalks are thick like bamboo though and are hollow.
I also weeded out the newcomers and stragglers on our property and JJ’s and Snoopie’s Yard.
On the abandoned house big piles of Knotweed are mulching.
Not bad for about 5 hours work. Lots of bending and use of my legs and upper body.
Cal
The war with Knotweed now is like a street fight where I broke the Knotweed’s nose. The fight is kinda over, and now is the time to end the fight and finish.
Pretty much the Knotweed is depleted and so weak it has no fight left in it.
BTW this invasive plant is mucho hard to defeat, and I did it without chemicals or herbicide. This was man verses nature, and because I’m stubborn I won.
This is a pretty big accomplishment.
Cal
BTW Phil’s bike buildout surely is no “Extra-Medium.” Phil went way out there to be retro, period correct, and pretty much did what perhaps only a few are capable of doing.
Lots of skill, knowledge and experience…
I am seriously humbled with my bikes.
Cal
Thanks for the praise but to be honest, I only remained faithful to the spirit and era of that bike. There's a lot of "cheats" here and there, but most folks wouldn't notice and only the most pretentious would even care that the headset is from the late 70s, rims the early 80s, saddle is only 30ish years old, the hubs predate the frame by a decade, all sorts of little stuff. Of course, there's the obvious brand new Sturmey Archer barcon as well as the bar end mirror, and the glaring handlebar bottle cage, which will be getting replaced with something more appropriate.
I do have a set of "sprints" for the Rotrax, which are wood filled tubular rims with no brake surface made for the Velodrome only. These are currently laced to a set of Brampton hubs. One of these days I will be finding the absolute correct NOS spokes for those wheels. I'll need to have the rims "rolled" in a kind of press to gently re-establish the roundness of the rim before lacing, as they have some flat spots. Then I'll need to find the best tubular tires I can find while maintaining the look of what should be period correct. Once those wheels get built and the decals and headbadge are on the Rotrax, I could say it is actually restored. If I get really crazy about it, I would use an inch pitch block chain, but those are going for insane money when they are available and they do sell. I mean more than $100 per foot and a track bike needs at least five feet of chain... Inch pitch roller chain is cheaper and a way to use inch pitch 3/16 cogs and chainrings, but in that instance I might as well just use 1/2" x 1/8" normal chain, since it's cheating on the build just the same.
Last fall I thought I had found the matching red flange Airlite hub for my restoration build of the R.O. Harrison. The front hub came from the UK and was NOS but it hadn't been properly packed, so the flanges were slightly bent. Mind you, the newest of these hubs is 60 years old and anodizing goes back to the 1930s. I can tell by the axle that this hub is post WWII, but not into the 60s when they adopted wider diameter hollow axles and wider shells for quick release skewers. These are bolt on track hubs with 5/16" axles. Anyway, let's say the hub is 70 years old and it has two slightly bent flanges. I'm not going to trust the flange on a front hub since it may have been work hardened from the impact and made more brittle. It was so sad. I told the seller, he filed a claim and I got a 100% refund and I got to keep the hub. So it's back to the old plan of getting my original Airlite matching anodized to the rear hub, then build the final set of wheels for the Harrison. These aren't priority issues, so I'll surely sit on the parts for a while.
Next project up is the Frejus, which is going to be much closer to original, once I find the correct front hub.
Phil
Tomorrow I go to my radiation oncologist for my blood to get drawn. This is the first one, and two weeks from now is the second. Pretty much close monitoring.
After the second blood drawing I have an appointment with my radiation oncologist to talk over the results. My side effects are not so bad. A bit lower energy and my body temperature regulation seems overly sensitive.
Cal
Today I go to my radiation oncologist for my blood to get drawn. This is the first one, and two weeks from now is the second. Pretty much close monitoring.
I’ll inquire about how long it takes for the inhibitor and steroid to get to full strength in my bloodstream. While the inhibitor by itself is no cure for Cancer cells that migrated and are undetectable basically atrophy and kinda starve to death. Since my Prostate Cancer migrated outside the prostate envelope the inhibitor does the function of a cleanup.
All you need is one viable Cancer cell and the Cancer has the potential to come back.
Cal
A mild CPI report, but tariffs surely will increase prices, the cost of living, and will increase inflation.
I say demand has softened, and the hoarding and buying in advance of the tariffs has mostly been done
Then there is the renegotiations and back peddling. Base protection is happening…
Understand that tariffs take time to have real economic impact, and the markets respond to news and is news driven. I understand this, but most people and the “base” do not understand this trickle effect.
Plan accordingly…
Cal
Gold took a 3% dive yesterday with the DOW shooting up over 1100 points on tariff mitigation/negotiation.
I mentioned how tariffs take time to filter into the economy. I also mentioned how the markets respond to news and news events, so the future will kinda sneak in like a rising tide. Expect higher inflation, higher costs, and a higher cost of living as time goes on.
Gold was over $3509.XX at one point, and now it is “ranging” around $3250.XX or so… Know that inflation will promote higher gold and real estate prices because they are a store of value.
So I predict that Gold will reach $3.5K again, and go north from there. Inflation will promote the price of gold northward.
Gold is a “hard” asset, and right now the markets are chasing “Paper” assets like stocks. Meanwhile the value of the U.S. dollar is less.
Here in New York tourism is down. Less foreign college students also. Even Canadians will avoid traveling to the U.S.
I also expect an economic slowdown is underway, but these numbers are not being reported yet. Consumer confidence is down, and American consumers account for 70% of our economy. The numbers have not reflected all this, and have not been reported yet.
So eventually, perhaps 3-6 months from now, the impact from tariffs might get reported.
I learned that next year I have to apply for financial aid again for the Inhibitor.
Cal
United Health Care is reporting mucho expenses and is taking the DOW into the red.
I had predicted that Covid would inflict a lot of collateral damage and increase mortality rates here in the U.S.
Seems that would be an explanation for the increased costs that UHC is reporting.
“Maggie” and I had to do a lot to recover and get on top of the screenings, maintenance, and preventative maintenance. Because of Covid and the pandemic the problem was trying to book appointments. Then we discovered that there are shortages of doctors, especially dermatologists. You have to book 6 months to a year ahead for dermatologists.
Then there are shortages for ENT doctors (Ear, Nose and Throat). This specifically is in New York, so I project and imagine it is likely worse in other parts of the U.S.
Preventative medicine and screenings save money for health insurance companies. Now is a post Covid surge in diseases.
Not that I’m a know it all, but I told you so… LOL.
Cal
A red screen today across the board. Gold remains above $3.2K…
I brought up my two Matchless amps from the basement, and now 4 amps underline the 11 guitars hanging from “The Wall.” The Wall is mighty pleasant to look at and it catches the eye. Impressive, and you don’t have to be a guitar player to appreciate it.
On my Pine Caster I added a string tree to the E&A strings, and it made a world of difference in tone. Much richer. Had to replace the “G” string and add more windings around the tuning post to balance the sound of the three unwound strings. I’m currently using 11’s on this guitar.
These little tweaks made a huge difference. I love the results.
Then I discovered that I have a steel E&A saddle so I could bump the brass E&A saddle currently on the Pine Caster to be used in the D&G strings to offer compensation using a heavier set of 12’s with a wound “G” string. I love it…
Today I take “Maggie” to her orthopedic doctor, the retired Navy SEAL doctor/surgeon, then tonight is the soup benefit for CHOP our local farm to table food pantry. Let’s see if Maggie feels up to it… BTW I don’t want to go without Maggie.
So for the past 5-6 days I have been Nurse Calvin and a caregiver. Maggie is improving a bit each day.
Maggie had a breakdown being an invalid earlier in the week.
With the “new” tariff deal there is 90 days reprieve to soften the blow and to eliminate the empty shelves scenario. Expect stockpiling, but surely this window of opportunity will eventually end. I personally can live without cheap goods from China, but the Walmart crowd that enlists most of America will be affected in a profound manner.
With all the smoke and mirrors know that noting really has changed, an economic slowdown is underway, and the value of the U.S. dollar is compromised. Expect inflation or worse stagflation.
Cal
Cal, when you go to Home Despot, check to see what is truly made in the USA. Back when I worked there in the hardware department, there was only one hammer and one hatchet in our whole tool department, which were made in the USA. Granted, that was 12 years ago, but I'm not going to give THD the benefit of the doubt, considering their bottom line. Interestingly, the Walton family has actually taken moves to improve the lives of their employees, even when flooding the USA with garbage. THD and Lowes simply use up their employees and have zero concern for them, if you ask my opinion. I'm not a disgruntled employee, either, I just think their administration practices are ridiculous. I've mentioned some of this behavior in past posts.
Anyway.
Rain, rain, go away. I want to ride my bike.
Phil
Phil,
It seems that many company’s don’t value employees, and they are disposable. Amazon is famous for this. This practice started with “downsizing” at the end of the Cold War. Ronald Ray-Gun fired Air Traffic Controllers and Unions lost their power.
Then soon thereafter stagnant wages happen that endured for decades. Then all the offshoring happened and a period of “disinflation” happened a phrase coined by Alan Greenspan for cheap imports, mostly from China that made stores like Walmart thrive that offset the stagnant wages.
We went from where 66% of Americans had Define Pension Plans to the era of 401K’s. Now I would say less than 30% now have pensions. I am lucky because I have two pensions.
I use to poll people I met and asked, “Do you think you will have your job (meaning present position) 5 years from now?”
The response was three quarters that I asked said, “I don’t know.”
The disposable employee mentality started many decades ago.
Cal
Status
Thread viewers
