wrs1145
A native Texan living far from home., but happy.
What is your opinion on the quality of the vintage Avenon lens as opposed to the Voitlander 21?
Thanks,
Bill
Thanks,
Bill
Thanks,
Bill
For film or digital (which digital)? For film CV CS 21/4 is easy choice. Same lens on digital M is fine for BW, but suffers from corners decentring in color. Even CornerFix can't fix it.What is your opinion on the quality of the vintage Avenon lens as opposed to the Voitlander 21?
Thanks,
Bill
Any pictures samples with it on M9?It's a great lens both on film and digital. I have a number of 21mm lenses (including 2 Leica lens) and it's far and away better. Plus it meters reasonably well with my M7, M9, or MP. The VF is huge but I use my Leitz VF.
The CV 21mm lens may be the main reason.I always wondered why someone has not come out with a new 21/2.8 with a similar design to the Kobalux but would work well on both film and digital.
Can you use your CV 21mm (Nikon S) on a Leica with an adapter?I don't know the Avenon but have the Voigtlander in 21 on both LTM and Nikon S mount. Love that lens and personally don't mind it on my M 240 but I'm not as fussy as some 🙂
For what it's worth, like Raid, I have the Kobalux 28 and also love it - if their 21 is as good and I didn't have the Voigtlander, I'd go hunting for the Kobolux first.
I don't know. Since I have it on both, I haven't tried and I have heard some of the CV lenses don't work. I'll try to remember to test it and get back to here on that.Can you use your CV 21mm (Nikon S) on a Leica with an adapter?
Are those corners?The CV 21mm f4 smears on digital much worse than the Avenon/Kobalux.
F5.6 on M240
F5.6 on A7RII
F11 on A7RII
Major downside on my Kobalux is it developed haze between cemented elements and is now most unusable. It was the millennium edition too.
Well that's quite impressive, but the Voigtlander 21/3.5 that I just bought is sharp right into the extreme corners at 5.6, as sharp on my M240 as this Avenon is at f11. In fact it seems crisp even wide open. Fred Miranda tested the 21/3.5 as pretty much as good on the A7rii as the M. It cost the same used off Ebay as the Avenon.
