Anyone use a grip with your Barnack?
Rayt
Nonplayer Character
1:33 PM
North Bay, CA
Searching for a grip for my IIIf I only found one from China. My 50mm F1.5 Summarit is a bit heavy and unbalanced on the IIIf and a grip ought to help. Anyone use a grip on their Barnack?
My worst lens for balance with my Barnacks is an 85/1.8 Canon, which I suspect is a fair amount heavier than the Summarit. I have the Metro Case grip which works well for attaching the camera to an Arca-Swiss tripod clamp but doesn't do much of anything to help with the balance with the camera hand held. I suspect this would be the case with any smallish grip on the right front of the camera because of the hand position required by the location of the shutter release.
What I found does work very well is a Leitz CTOOM flash bracket. It lets me firmly support the left end of the camera leaving my right hand free to just support the weight of the right end of the camera and operate the shutter release. And as a nice bonus my little Voigtländer VC light meter mounts nicely in the cold shoe on the CTOOM with my left thumb perfectly located to operate the pushbutton on the back of the meter. (That's a front view below - my references to front and back are from the back of the camera.)
N.B. The CTOOM was made with both 1/4-20 and 3/8-16 mounting screws. When I was looking for one a number of years ago the 3/8-16 was more common. Many eBay sellers didn't know the difference.
Just the ones with the bump built into my Luigi and Zhou half-cases.
I use a Summitar and a Summicron on my two IIIfs and don’t know how they compare in weight to a Summarit.
The Summarit is heavy like a block of metal and probably not the best choice for a little Barnack but it’s the only screw mount 50mm I own. A Zhou case is a good option. Thanks.
I have a 85mm Summarex and if I ever use it on a Barnack then this would be an option.
I guess the Zhou case is going to get a big tarrif bill if I order one now. They appear to be the best looking reasonably priced barnack case out there.
Is it still around $65? Still a bargain with T tax and not many other options for Barnack.
Yeah. I almost ordered one yesterday for the iiif I just got back from YYE but there’s Ben so much bank and firth I’m not even sure what tarrif is today. Hopefully not the 150% that was threatened for a minute.
An aside I know is not the case but I like to imagine there is really an 80yo Mr. Zhou hand making all the cases. 😜
Rayt,​
The yellow filter on the IIIf could use a clean 🙂
I don't use a grip with my If & IIIF cameras. I do with my M3 and M4-P. The grip I use with my M cameras is the Leica Motor Drive
M3-MOT w/Canon 50mm f/1.2 & shade
Thanks to the inspiration on this thread, I whipped up a 3D printed base that holds a walnut hand grip. I didn't necessarily have an issue without a grip - but I do feel I have a safer hold of thew camera using the grip. It stays attached to the bottom plate when loading film, so no additional hassle.
found this really nice wood one, ive seen other people comment some 3d printed stuff but i honestly think this is better personally
That does look really nice, made of wood and metal not light plastic like the one I got.
Yeah, I’m thinking of getting it for my IIC as I don’t much like the pinch grip, for some reason it states that it’s only compatible with IIIf/g, I think it just may be that they haven’t tried it on a II or I series camera but I’m not willing to risk 100$ on a grip that might not work, I do like it a lot better than others that I’ve found because it’s actual wood and metal that will match the camera very well instead of that cheap plastic
