My Rangefinder search...
Klikkie
12:28 PM
Holland
Hi Guys,
Im new to this forum, so I'm looking forward to learn a lot from you Rangefinder lovers.
Right now Im on a quest to find a decent rangefinder for max. 1000 euro. I've been looking around and the search is more of a quest now.
The tings I'm looking for in a rangefinder are:
- Reliable lightmeter
- Good build quality
- Max 1000 euro
- Good quality glass. I love good sharp and contrasty lenses.
- Fixed lens or not... doesn't matter.
The rangefinders I already came across are:
- Konica Hexar (RF) (A bit over my max)
- Minolta CLE
- Canon QL Giii
I already have a nice Zorki 6 and had (and sold) my Kiev 4. I find the viewfinders on these soviet cameras to be pretty small and dim. Also fast focussing is not very easy with the small dim patches.
But I have a feeling there is so much more to find and doesn't have to be expensive.
I would like to get some advice on this from you rangefinder specialists.
Thanks a lot!
I would suggest starting with a fixed-lens rangefinder, as I see the Canonet QL Giii on the list. This will run much less than the others on the list, once adding a lens. Electronics on the Minolta CLE are getting old, but there are specialty repair shops that will still take it on.
The Canonet QL Giii has a fast 40/1.7 lens on it. This camera also has manual mode, but the meter does not operate when turned off of Auto.
Minolta made the Minolta AL-E, compact camera with 40/1.8 lens. The Minolta has shutter preferred auto mode, and manual mode with metering.Minolta_Canonet.jpg
If you do not mind a full-size camera:
The Minolta Hi-Matic 9 has a 45mm F1.7 lens, has full-programmed mode of operation where the camera sets both shutter speed and F-Stop. The camera also has full manual mode with metering. The 45mm F1.7 lens on the Minolta is sharp even wide-open.
The Konica S-2 is another good choice. 45mm F1.8 lens, and a unique viewfinder with both auto-parallax and field-of-view correction.
These cameras - the Canonet, Minolta, and Konica are from the early 1970s. You want one that has been serviced, and being sold by someone that has used it.
Welcome!
I would suggest a later Bessa R/R2/R4. This may hit your spending limit, but you would have access to a wide range of vintage/new/cheap/expensive lenses.
If you drop the requirement for a working light meter, there are many vintage options.
New clip-on light meters are available and are fairly inexpensive.
And you would have money leftover for a 2nd or third lens.
Suggestions:
Later Canon rangefinder: VL/L/L2/P/7
High quality, access to many L39 screw mount lenses from Canon, Leica, Nikon, Voigtlander, Leica.
Multiple frame lines in the viewfinder, varies by model.
Nikon S2: great viewfinder for 50mm only. Solid camera. Not as wide selection of lenses but both vintage and fairly modern available.
Agree about the suggestion for a fixed lens camera -- and the Canonet G III is a great suggestion. No need to go straight into "Leicaland."
He's got a Zorki and has had a Kiev....so he's got experience with rangefinders. Also with a budget of 1000€ + ....... why start at the bottom and climb the ladder again?
Thanks fot.the tips so far! I really appreciate it.
The Canon is on my mind, as well as a Voigtländer Bessa (although still looking for the right model). And true enough, I don't want to start at the bottom, but then again, why spend a 1000 euro, when there is a secret gem hiding for, let's say 300 euro.
K I think you'd have to look long to find a gem @ 300€.....unless you limit your desires. Do you want to limit yourself to a fixed lens....say 40mm?
Even a cell phone these days offers more choice. IMO it's sure nice to have a camera you can mount your favourite focal length lens. & companies like Voigtlander/Cosina, TTArtisan et al are making many lenses available.
"The Bessa with a Summicron, out of reach."
The Bessa in #9 is sporting a Voigtlander lens.
You could get this Bessa with a lens... for 600€
or you could buy a Bessa body and an M Rokkor 40mm...which is a Summicron....
Lots of Leitz/Minolta CL on Ebay for 800-900€
Light meter is obstacle.
Mobile phones light metering app does it better. It will teach you S16 within few months.
Go with Canon P.
Bessa R will do as well. It just have very non wear resistant exterior.
Or just get Leica LTM. Small and beautiful. No clones are as good.
It doesn't cost a lot, it will be money for lens as well.
Last thing on reliability list are old RFs with electronics.
Ko.Fe "Last thing on reliability list are old RFs with electronics". 👍
Recommended by people with shelves full of expensive cameras and lenses........ to someone with a 1000€ budget....????
Cameras that retailed for $90 when new in the '70s and were pretty much yard sale give-aways until recently.........
Thanks! I'm looking now into the Bessa R, Canon Canon QL Giii and Canon 7 (but I don't know about the reliability of the meters). I was reading up on some other camera's and I started to get a little worried about repairability and dying of electronics. I don't want to waste my money. So maybe I should let go of the lightmeter, unless it's a really reliable one. On my list I put a Canon P. Maybe it's better for now to aim a bit lower than the 1000 euro... Just in case
Canon P -- Yes!
