first batch Nippon Kogaku 135/4 Serial
splitimageview
coincidence rangefinder
Staff member
10:24 AM
Austin
Roland's site has the 611xxx batch listed as 1948, is this correct? Or is it 1946?
TypeLensCountryStart NoConfirmedQtyDate
S13.5cm/4 Q·C TokyoMIOJ611 1611 38 - 611185185Nov 1948
S, M3913.5cm/4 Q·C TokyoMIOJ904 01904 12 - 904755755Dec 1949
S, M3913.5cm/4 Q·C TokyoMIOJ523711 - 524028318Dec 1950 - 1951
It is possible that the 611 series was designed in 1946 and some production may have started that early. Since the 904 series did not arrive till about Dec of 49 there would have been no teles for the first Ones coming off the line in March 1948 so the 611 series may be there and for sale.
611232 is on kevin cameras site. LTM
SCAP records indicate that the first 135/4 Nikkors made it through production the first of November 1948. These were almost certainly in the 611 series. Serial numbers indicated design completion and had little or nothing to do with actual production. This chart is a good summary of the 135/4 production.
I guess NK could’ve made some after design completion but didn’t report to SCAP till the camera was out. It’s interesting that there are LTM examples in the first batch, 611232 is way past the 611185 number listed above.
Kiu
Here and there I have submitted serial numbers that extend Roland's database a bit. He should be notified of the one at kevincameras.
