Valkir1987
I switched from an acid fixer, to a neutral fixer a long time ago. Using the stop bath makes the chemistry (especially your fixer) last much longer. I shoot bulk film in combination with a stock developer and short films. It makes the workflow easy.
When done with the fixer, (and the first rinse with clear water) I use a soda bath. It reduces stain on your reels and tanks, and helps to rinse out the fixer. Final rinse in demineralized water.
Amaloco tested the water rinse versus the stop bath a while ago. When using short developing times, the films with the stop bath gave a more even density. A difference that cannot always be noticed, but can be measured.
