first steps with the KEKS M Meter
hans_kohler
11:41 AM
Austria
I recently purchased the new KEKS M-Meter and wanted to share my experience regarding its battery performance, since this aspect is not clearly communicated in the official product information.
According to the KEKS website and product manual, the M-Meter comes with a rechargeable 240 mAh battery that provides “>10 hours continuous use” after a full charge. This matches what some reviews have reported – for example, Digital Camera World mentioned that after shooting 12 rolls of film over two weeks, around 30% battery was still left
However, in my own use I noticed something different: even when the M-Meter is switched off and left unused, the battery drains by more than 50% within a few days. Within one to two weeks of not using it, the battery is completely empty.
I contacted KEKS support and here is their reply (quoted):
> “Regarding the battery drainage issue you've experienced with your KEKS M-Meter, we can confirm that this behavior is completely normal. The M-Meter does draw a small amount of power even when it is not actively in use, which is why the battery will gradually deplete over time. It is indeed normal for the meter to fully drain within a couple of weeks if left unused. If you leave the screen on, it will last for over 12 hours.”
So, while the official specifications are technically correct (>10 hours of continuous use), what is not disclosed is that the device constantly consumes power, even when not in use. This means you cannot leave it sitting in your bag for a couple of weeks and expect it to still have charge.
Personally, I find this disappointing. In my opinion, a well-designed light meter should consume zero power in the “off” state. At the very least, the manufacturer should clearly state this limitation in the product documentation so users can plan accordingly.
In practice, the solution is to keep the M-Meter charged regularly or carry a power bank when shooting. But for potential buyers: be aware that the battery will not hold charge for long if the device is left unused.
Good info to know. How long does it take to charge? Shouldn't be long at all.
In my experience with devices that have small rechargeables, for example Shokz headphones, it's best to charge them only until full but not plug them in for extended periods. Otherwise the batteries have a much shorter life and they are not replaceable so that means the headphone must be thrown away, something I have had to do more than once.
For an easy automatic charging system, I've set up a Kasa smart plug, which is programmable. The Shokz will charge in about 90 minutes to full, so I program the smart plug to automatically turn off after 90 minutes, and the Shokz charging block plugs into the smart plug.
Press the on switch once, and walk away, no need to remember to disconnect the Shokz, the charging will stop automatically.
I have several rechargeable devices that use this same system.
@keks_camera maybe something that should be mentioned in the user manual!
That's disappointing. I wonder why the unit has to have power all the time, even when "off"...
Probably because it has to be watching for the button press to turn it on. It isn't a physical switch that disconnects the battery, it is the same button you use to take a meter reading.
If the battery completely dies is the ISO setting retained in NVRAM or does it have to be reset? If so what's the default ISO when power is restored?
Thanks for posting. I just got the meter and will keep an eye on the battery issue. On another note, the Keks M Meter did not fit properly on my 1954 and 1964 M3's despite the MR4 meter fitting on both perfectly. Contacted Keks support and they told me that I needed to unscrew their bottom plate with an allen key that was not included to reposition the fitting. Went to the hardware store and did this as well as "repositioned" the cold shoe on the cameras. With this and very hard pressure against the meter I am able to get it to fit in. I actually asked them to replace or refund me (even offered to let them do it when I am visiting Hong Kong in a couple of weeks). There reply was quite unhelpful stating that they would not provide a refund for it not fitting correctly. They never even offered a replacement. Not very happy with the way they treat their customers and would not recommend purchasing anything from them given fit issues and really poor customer service. I tried to explain to them that the MR4 still fits in perfectly which each camera but the Keks M meter does not. However, they insist that everything is perfect with their product. NOT......
It is always in "stand by", feeding an internal programmed micro controller which will always takes a small current in stand by. And most Chinese small accumulators which are used for these devices have not always the best quality. So in a few weeks or less, it is empty.
Having a horrible experience so far. Meter would not fit properly on 2 m3’s. After much adjustment with very poor help from customer support managed to get it to fit. My original mr4 fits perfectly on both. Battery life really poor even if not used. Now meter not working at all. Customer service still piss poor but now at least allowing me to send back to Taiwan for repairs. I had to send multiple videos to prove this. In the 6 weeks I had it I was not able to shoot a single roll with it……
hmm. Have to say, I prefer the Voigtländer VC Meter II that I've been using for the past decade or so. I prefer the user interface, don't care at all that it's not connected to the shutter speed selector, and they're still available new from CameraQuest.com or B&H in black or chrome finish. And used. A pair of LR44s in it lasts years...
I prefer it to the Leica MR-4 meter, actually, and use it much more often.
G
I’ll have to agree about the short comings of this product. I had a difficult time mounting mine on an M2, but finally got it to fit. Tried it to determine accuracy and was happy it seemed to jive with known meter readings. It sat on the M2 and when I picked it up again to look, the battery was dead. I now know it’s performance in that regard and if I had known of this prior to purchase, I probably would not have bought it. It’s not like I’m using this camera on a daily basis, so when I do, I’ll make sure to charge it fully. My question is, if left uncharged for an extended period of time, will this be detrimental to it’s working down the road? Wondering if anyone has experienced that scenario so far?
Should have stuck with my perfectly working MC meter which is still accurate after all these years!
Oh well, I still have it and really wonder why I wasted $100….😒
