Mcary
Decide to start with Epson Velvet Fine Art and Moab Juniper Baryta Rag for B&W prints, the like the results for both but like the Moab a bit more. May give one of the Canson Infinity Baryta papers a try next.
I've heard very good things about both Canson Infinity Baryta papers: the Photographique and the Prestige IIMay give one of the Canson Infinity Baryta papers a try next.
I actually have that installed and just ran a couple of prints. You're right about the learning curve - using the included profiles and default settings, it looks very weak compared to ABW. I'd have to spend more time than I'm willing to get deep into that.If you want ultimate control of black and white you might want to check out Quadtone RIP which supports the P700. There are some premade profiles for different papers which you could try and then tweak from there. But it is a steep learning curve.
So now that I've been printing like crazy for nearly a week, I have some observations.
- This Ilford GFP paper is really well-matched to this printer. I only tried one other glossy baryta paper (Pictran), which is actually quite close, but the surface of the Ilford looks just a hair better to me. Since the only other baryta papers readily available in Japan are the Pictran and much more expensive Hahnemuhle and Canson, Ilford it is for me.
- "Ink Low" doesn't mean anything, apparently.
- Smudges on the borders can be solved with the simple platen gap, as has been detailed elsewhere online.
Now for the question part:
I ordered a sample pack of Awagami washi papers, just out of curiosity. They are all matte papers , and even though I think I will do most of my main printing on the glossy Ilford (well, pearl), I'd like to make sure I am getting the best out of these papers in case I want to use them for real one of these days. They have a great feel.
So any recommended settings to get a solid black and good snap/contrast? My test prints so far are nice and detailed, but since I am used to glossy, just not very deep and snappy. I tried increasing ink density and adjusting the ABW settings to get more contrast, but nothing was quite substantially more "wow" than my usual settings. Some were a little muddier without being significantly blacker. Do people use fairly extreme settings with matte, or is this just the ceiling of what can be done with it? I used the Epson Velvet media type.
I looked again at some manufacturer sample books (Ilford today), and they manage to get insanely black blacks on their rag and other matte papers, so I’m thinking the Awagami just might be particularly not great for dmax. Just wanted to make sure it wasn’t user error. I set the media type to Velvet, which should switch to matte black ink automatically.Matte papers always look weak compared to glossy; there's nothing you can do to change that. Make sure you use the Matte Black Ink for your matte papers; that does make a big difference, though the matte prints will still never have the deep blacks of a glossy paper.
Kozo papers, like Awagami, are poor to terrible for DMax. The blacks of platinum develop-out emulsions, the highest DMax materials that I know, on kozo look . . . mildly dark.I looked again at some manufacturer sample books (Ilford today), and they manage to get insanely black blacks on their rag and other matte papers, so I’m thinking the Awagami just might be particularly not great for dmax. Just wanted to make sure it wasn’t user error. I set the media type to Velvet, which should switch to matte black ink automatically.
Thanks. That explains it then. I may have to buy some Ilford Cotton Rag to satisfy my matte-curiosity.Kozo papers, like Awagami, are poor to terrible for DMax. The blacks of platinum develop-out emulsions, the highest DMax materials that I know, on kozo look . . . mildly dark.
I just found a sample pack of the ilford matte papers, so we will see what happens when that arrives.It might be worth buying a sample test pack of papers if they are available from the manufacturer.
One thing I have found is the presence of optical brighteners makes a big differece to the look and contrast of a (especially) matte print. The ones often labelled 'bright white' look completely different to the non-OBA warm papers. But the OBAs degrade over time and shift the tones of the original print.
I also find that printing a 'neutral' image on a warm paper often results in a greenish hue which I don't like. You have to experiment.
This is absolutely true, it's a physical factor. In my work in a chemical company in the color field, dyes and pigments I was oft confronted by clients with the point "that competitors black is deeper than yours" but a real comparison can be made only if two different black have the same grade of opacity. You can see the difference printing a subject with a large part of black on a matt paper and than cover part of it with a transparent piece of plexiglas: you will notice how the "not vivid" black changes charachter!Matte papers always look weak compared to glossy; there's nothing you can do to change that. Make sure you use the Matte Black Ink for your matte papers; that does make a big difference, though the matte prints will still never have the deep blacks of a glossy paper.
So everything has been going well until some recent prints that are showing a serious issue in the shadows. Anyone see this before and know the cause? I thought it may have been due to the matte papers I fed through, but there are prints I made after that without the issue. I also just tried a sheet from a box of the same 5x7 Ilford Gold Fiber Pearl (the issue is with an A4 box), and it prints fine. This points to a bad paper batch, but some other prints I made from this box were ok. I really hope this expensive 100 sheet box is not ddefective. I tried a sheet from the middle of the box, and it shows the same problem. Tried paper path cleaning and head cleaning with no effect. Also made prints at multiple quality settings both with and without the black overcoat thing.
Lol, yes. It's hard to mess that up with the Fiber Pearl.Did you print on the correct side of the paper?
