Rolleiflex 2.8C Shutter Guard Concern
10:08 PM
Singapore
Hello,
I'm about to purchase a Rolleiflex 2.8C that I think is in a very good condition. I'm a little reluctant because of what I've read about the shutter/flash socket locks being prone to breakage. May I ask, will I still be able to lock and unlock the shutter button if the plastic part of the guard fails? I fear it might be near impossible to find a replacement part, what would be the alternatives? I've asked ChatGPT and those AI agents these questions and I could never seem to believe them. I'm hoping for some human touch in my quest for answers that might help in my decision. Thanks!
Hello,
My user* Rollei is a 2.8C with the Xenotar and 10 blade shutter. The metal parts from other Rolleis can be fitted to the 2.8C. If the plastic fails you can unlock the shutter with pliers. I never locked the shutter button and just put the camera away without winding on/cocking the shutter.
*I used it a lot in the 2000s but haven’t run a film through it in over 10 years.
@Freakscene and @monopix, thanks for sharing your thoughts. Viewed the camera today, and I've decided not to get it. There were a couple of very noticeable particles inside the lens, and what looked like rust on the aperture blades. For the price ($1200), I thought I should not have to get it CLA'd. My search continues.
Hello, good people of this forum. I've had a 2.8f for a day now, and I noticed that when I have the shutter speed set to 60 sec, the aperture can only go as wide as f16. And when I'm at f2.8, I can only set the shutter speed as slow as 2 sec. I'm getting mixed replies from AI agents, one says it is a feature in earlier assemblies of the 2.8f, another says it is a mechanical defect. What say the good people of this forum? Many thanks!
Have you read the manual?
Thanks! I've checked, but I could not find any mention of aperture limitation when using slower shutter speeds (i.e. 60 sec). It does mention that I can use f2.8 via manually controlled time exposure with the shutter speed set to 2 sec (and locking the shutter after pressing). Would be great if someone who has a 2.8f to confirm that the an f16 max aperture limitation when shutter speed is set to 60 sec is by design.
It’s probably limited by the lightmeter. You cannot go beyond the scale.
But why would you want to use those settings? The shutter does not go beyond 1 sec and the lightmeter cannot meter this amount of light.
Are the shutter speed and aperture linked? On the front of the aperture ring there is a groove. You turn that groove 90 degrees to uncouple the shutter and aperture rings.
The coupling is designed to let you make a change in aperture or shutter speed, and both will change equally at the same time.
If you want to make separate adjustments the shutter speed and aperture need to be uncoupled by turning the groove 90 degrees.
Hi. The 2.8F (at least the one I have) does not have this feature that the 2.8e has. And I could not find a button or a switch that might be assigned to this feature on this 2.8F. Thanks.
