I thought for film you initially were implying that it was rangefinder coupled. Now I understand.
I am currently looking around with a view to purchasing a Leica iiif.
If you're looking at a IIIf, you might want to consider the Leitz-made 50mm LTM lenses purely because they can (almost) all focus using the rangefinder accurately to 0.5m on a IIIf... with the right tools.
The widget on this IIIf is an early version of the Dual Range Summicron concept - the SOOKY. Unscrew the lens, collapse it, hook the bayonet at the back of the lens' collapsing tube into the SOOKY, and screw the SOOKY onto the camera. The round lens in front of the RF window changes the focus point, the frame in front of the VF window has a moving cropping frame to adjust for parallax (with amazing precision, I should add), and then you focus with the helical in the SOOKY instead of the one on the lens.
There's three versions:
NOOKY: for the 50mm f/3.5 Elmar
NOOKY-HESUM: for the Summar, 50mm Hektor, and the Summitar
SOOKY: for the collapsible Summicron (and, I believe, the 50mm f/2.8 Elmar)
All work the exact same way, so you just need to get the right one for your lens(es).
They're obviously not the fastest thing to mount, but when you need to focus between 50cm and 1m, they work perfectly. The biggest issue is depth of field, because wide-open with the f/2.0 lenses, you basically have a sliver to work with at 50cm:
This was with the Summar at f/2 and 1/30. In normal circumstances you really want to stop down a bit to have a more sensible depth of field!
