Leica announces new steel-rim Summilux 35mm f1.4 lens
From what I've read, the Voigtlander Nokton 35mm f1.4 was based on the Leica Summilux 35 pre-aspheric. Is this the lens upon which the Voigtlander was supposedly based, or is it another? I have the Nokton, which is a bit glowy wide open, and has significant soap bubble bokeh that I presume is part of its intended character. Does anyone know if the new Summilux reissue has this kind of rendering?
The Re-Edition Steel Rim Summilux does not have "soap bubble" bokeh. To my eyes, it has what I consider to be "busy" bokeh.
It’s similar but there is one fewer element in the second group of the front section of the Leica design. C-V no doubt added the element to increase correction. The rendering is very different.
No, not at all.
In this shot the coma is clearly visible.
gelatin silver print (summilux 35mm f1.4 steelrim v1) leica mp
Utrecht, 2017
Looking at your work is like peering into a dimension of classical proportions and rendering. There is a timelessness to your images which remains regardless of subject or environment. You could be in 2040 Guangzhou taking photos of otherwordly modern architecture and people, and they would still have the impression of being taken in some indeterminate time in the past.
