ChrisPlatt
Thread Killer
I had BX20 and BC1 bodies. Both broke in short order.
I will look for a working B200. Thanks for the advice.
Chris
Chris
I finally bought Flektogon 35/2.4. I found it relatively cheap, it was quite abused cosmetically, but the seller assured the glass was clean and it worked as it should. Well, it came today and the glass was indeed clean, but the A mode did not work - the aperture pin was loose and not doing the job. So, basically, it worked only in manual aperture mode. I removed the back plate- the arm which is pushed by the aperture control lever (in order to open the aperture) was deformed and the level was simply not catching the arm. I spent the evening figuring out how to fix it without any spare parts (and without breaking it more). I think I managed, so I will finally be able to test this lens during the weekend. Maybe I simply should have bought the one in good shape, spending 100-150€ more.
I like the f/2.4 MC Flektogon, great sharpness and color rendition, but man does it have barrel distortion.
phillipreeve.net
Maybe I simply should have bought the one in good shape, spending 100-150€ *more*.
Call me a pedant, but I don't consider a 1942 lens "East German."Just an M9 shot with my sweet old '42 5cm 1.5 CZJ of the 27nnnn series. It works well on the M9 sensor.
L1003418 M9 + '42 5cm CZJ 1.5 of the 272nnnn series of magic lenses by West Phalia, on Flickr
Were any of these 28/2.8 made in Japan by Cosina? I seem to remember reading it somewhere.Zero barrel distortion on the Pentacon 28mm f2.8 (a good example) on film:
Prakticar 2,8/28 | zeissikonveb.de
I think it should mean DDR (i.e. East Germany) -- otherwise any Carl Zeiss Jena lens would qualify.Perhaps some clarity is needed here. Does "East German" designate from Eastern Germany or from the DDR? The classic query of "define your terms."
The outside screams sigma to me. I had the mini wide and still have the super wide. Maybe the lens design inside is Pentacon.Very likely, perhaps with a more simple different optical formula. Retailers and distributors used the name Pentacon, Carl Zeiss Jena and Prakticar on a lot of Japanese and Korean import lenses to fill in the demand.
Just spotted one for sale:
Pentacon Prakticar 28mm f/2.8 MC Lens voor Praktica B Mount | Reway
