RF recommendation for a newbie to exposures and film
PictureThis
6:03 PM
Monterey, CA
My daughter who has been raised on DSLRs wants to get an affordable rangefinder. She has just started using my Nikon FE2 and we’ve been going over how exposure works. She can always fall back on auto with that camera.
The features she would like
- smaller 35mm
- good quality but not Leica $
- maybe an aperture priority auto
- cool vintage look and feel
- built in view finder, rangefinder, parallax
- built in meter? Doesn’t want to carry a meter …be right back… of course! There are mobile apps for that!
I was initially thinking of the Bessa R but heard it’s made of plastic and cheap feeling. Anyone confirm or debunk that?
Most non-Leica rangefinders predate the era of built-in meters. The only one I can think of that is not a Leica, modern Voigtlander or Zeiss Ikon is the Canon 7, but that's on the bigger side. Check out the classic camera profiles on the cameraquest website. Lot of good info there in one location.
Do you mean your daughter wants parallax or wants parallax correction? The Konica IIIA and IIIm are about the only 35mm rangefinders with proper parallax correction, but they don’t have meters.
The Olympus 35 RC is a great little rangefinder. Very sharp 42mm f/2.8 lens, shutter priority auto exposure, aperture and shutter speed indicators in the viewfinder, and the shutter speed controlled by a dial on the top like God and Oskar Barnack intended. You can get one for less than $200 on the auction site. Ken Rockwell has a good review of this camera.
Thanks I will check that out
She like doing closeups sometimes - not necessarily macro but close enough where parallax would be a problem. She has a fuji polaroid and it took a bit of explanation of why the flower was not in the print. My Fuji GL690 compensates as you focus.
I think not having a built in meter wouldn't be a deal breaker given that her phone could be the meter. Was reading that the old selenium cell type go bad anyway. I will look at the Konica, Olympus etc.
She played with a Kodak Retina iiic and liked it - fast 50mm f2 and cool folding door. Supposed to be a good camera too. Also looking at the Nikon S / S2 and Canon P. Very nice looking but never held one. We went to a camera show last weekend in Newark, CA and got to play with a few different ones, but much smaller show than I am used to - but its been a long while.
The Bessa R was my primary 35mm film camera for a long time. It was not cheap feeling but it did have plenty of plastic.
If interchangeable lenses are not a priority, there are lots of good possibilities. Working condition is, in my view, more important than specific brand.
I will suggest avoiding cameras that require mercury batteries. They are not inherently bad but they can be fiddly or expensive to use with modern batteries.
- smaller 35mm
Dear PictureThis,
As an owner of a Bessa R bought second hand, I'll second the recommendation of rbiemer. Yes, it is mostly plastic, but I'm still using a plastic Canon EOS Elan bought new in 1993, so plastic doesn't scare me. 😉
I also have a Canon 7 that I use. I enjoy using the Bessa and the Canon but actually prefer the Bessa R for the 1/2000 top shutter speed simply because it offers a bit more versatility when I have ISO 400 speed film on hand. In addition, it is considerably lighter in weight while still being comfortable to me to hold and use.
If your daughter doesn't need the ability to change lenses there are dozens of worthwhile 35mm rangefinders to consider. I have several fixed lens rangefinders that I would recommend with the caveat being that it must be in serviceable condition, or she is willing to bear the expense of a service.
Here is the short list.
Canonet 28 or GIII 1.7
Minolta Hi-Matic 7
Yashsica GSN
Vivitar 35EE
And last but by no means least, a Kodak Retina IIa or IIIc, big or little C is of little consequence. They are however fully manual cameras but the III versions do have a light meter. My IIIc has a meter that works just fine.
Good luck in the search, there are other worthwhile candidates to consider for sure!
Regards,
Tim Murphy
Harrisburg PA 🙂
Tim and everyone - Great advice. Kinda overwhelmed with all the good options each with their own tradeoffs. I think she'd use it more if it had an auto exposure mode - some of all the recommendations do although the meter use in manual is a little odd.
Ideally if it was a rangefinder version of a Nikon FE/FE2 it would be perfect. She is using an FE2 now and the want auto (aperture priority) works is so easy - it's on the shutter speed dial and just another option after all the manual shutter speeds. Then you have match needle in the view finder. In auto it shows the shutter speed it will use, in manual it has a pointer that indicates the correct shutter speed for your chosen aperture but you have to set the speed to match - super logical and great way to get comfortable switching to Manuel.
Any rangefinders that work like that?
Absolutely nothing wrong with the Bessa R. I have one and it's been great. Used it exclusively to document my son's ski team adventures for 5 years. Not for a fragile camera. Mind you I was cognizant about not abusing the camera for sure.
My favorite non-Leica rangefinder camera is a Kodak Retina IIIc/IIc ... The IIIc has the f/2 lens and a meter in it; the IIc has the f/2.8 version of the same lens and no meter. The lenses on both are excellent, the IIc is a bit lighter and I find the IIIc meter pretty limited at best, when it works (rare). You can get 85mm and 35mm lenses for these cameras too. You can find either of these very inexpensively (I've bought serviceable ones for as little as $10), but they'll usually need to be serviced since they are old and full of coagulated lubricant and dirt from sitting, so figure about $200 anyway. With the standard lens, they fold nice and compact for carrying, and the lens is the equal of a Leica 50mm Summicron for all intents and purposes.
And they're cool, classic looking. People see you holding them and want to be photographed with them. This helps a lot if you like taking street photos. 🙂
G
Decision made: Canon QL17 Giii
Small, light, auto exposure, manual, quiet. Found a nice one that will need a battery solution and the light seal replaced possibly.
My favorite was the Bessa R - might get one for me at some point
Close 2nd was the Canon P - strangely in love with the rewind knob design and more shutter speeds than Nikon S2
3rd Nikon S2 - the early Nikon "N" is so much more stylish than the current logo
Thank you all for input!
Rob
Rob
I think this is a good choice for your daughter. Going from aperture-priority automation to shutter-priority should be an easy transition.
I haven't tried it yet, myself, but an MR-9 adapter and a 386 silver oxide battery (flatter than the more common 357), should solve the lack of mercury battery.
- Murray
- Murray
Just an FYI, a 675-hearing aid battery inside a #9 rubber O-ring also makes a suitable substitute battery for the Canonet 28 and G III 1.7
Regards,
Tim Murphy
Harrisburg PA 🙂
Thread viewers
