Artorius
Caribbean Traveler
I've done the search. I need a 35mm film scanner under $500.00. Which one?
40oz said:HP Photosmart S20 is well under $500 used. Only does up to 2400dpi, but is focus-free, and requires no film holders. Does strips of up to 5 frames in a batch, slides as well (in holders or strips), and doesn't care what color the film base is as it seems to automatically compensate. Doesn't have any kind of scratch or dust removal, but since I use it mainly for B&W, that is not an issue for me. The auto settings almost always are the best you're gonna do. Does 24-bit color from Photoshop, but not from the HP software.
See my gallery for scans.
Artorius said:I've done the search. I need a 35mm film scanner under $500.00. Which one?
jky said:The Minolta DualScan IV seemed popular around here when I was doing my research on the topic... they can be had for around $275.00 on the auction site. For not much more than your $500.00 limit, you can get a Coolscan V, which gets wonderful reviews. Other than these two, there are some flatbeds out there that may fit the bill. I bought (and returned) a Canonscan 8600f flatbed scanner. It was a decent flatbed and can pull detail fairly well. The images required plenty of sharpening as they were somewhat soft (expected from a flatbed I guess), but after some USM the pics looked good on the monitor. I only returned it because I don't shoot enough MF.
Cheers, j
pmu said:Is there any flatbed scanner (epson preferred) with 35mm holders that flattens curly negatives? You know, with dedicated film scanner the filmholders are built so that the film is pressed flat between the frames, but I haven't seen any flatbed 35mm filmstrip holder with that kind of desing -- they just hold the negative from the sides and there is nothing that falttens the negative, right??
anglophone1 said:Also scans panoramics!
Clive
johne said:I admit my ignorance. I have an old Acer 620P scanner. I scanned a negative to see if I could. I had to put a blank white strip of cardboard on the negative to get a file at 4000DPI. Now what? I took it to a Walgreen store and they could not make a print from it. [It was on a portable "carry" that had USB 2 connections they said they could not use. Odd.] What am I missing? Tech impared but curious.
Johne
I suspect it may be just a lack of knowledge by employees of this particular store. They said they could scan a negative there in the store. The USB2 connector seems to be the fly in the ointment here.
johne said:Artorius,
I had the digitalized negative on the hard drive. I downloaded it onto a one gig portable storage unit to take it to the store. Perhaps I am calling the device by the wrong name. [It is a PNY Attache.] On the old flat bed scanner I found I could not get enough light to scan a negative. I took a white strip of cardboard the size of the negative and put it over the negative to reflect the light from underneath. It worked.
Johne
