polariser advice
suselko
suselko
11:48 AM
Edinburgh, UK & Krakow, Poland
Hi!
I have a question about polarising filters that maybe one of you knows the answer to. (I haven't worked with polarising filters so far, hence my ignorance).
Inspired by some of the posts on this forum, I am considering mounting one polariser on my lens, marking edges with numbers, holding another polariser in my hand to check which setting is the best, and setting the one on the lens adequately. But i'm not sure if I had two polarisers of different make, would the result be OK? In other words, if we ignore the quality of glass, do different polarising filters show the same image? Or maybe I need two identical polarisers? Thanks for help,
Filip
There are apparently more robust solution of utilizing a polarizer on RF:
Check out FIlterView device on: www.photoequip.com - appears to be exactly the solution for RF. Do not have any personal experience neither relaiton to them, but will cnosider purchasing it as soon as will get into any considerable landscape shooting with my Leica.
Yes that will work regardless of the polarizer. However a DIY solution like this will work easier:
attachment.php
I use two polarisers on my Bronica.
i engraved them both with numbers after checking the direction. Works like a charm. Afaik all polarisers work the same way.
On the Leica I use the universal swing out filter. Also works very well. if you can afford it.
Robert White also sells a solution for RF's.
Michiel Fokkema
I think I'm missing something here. You want 2 polarizers on the camera? Why? What are you going for?
If you put 2 polarizers at 90 degrees they will not allow any light through.
Steve
Robert White (and maybe others too) sells a cheap polarizer by Tiffen that is mounted on a small handle like a magnifying glass that is great for evaluating polarizer alignment. It is graduated in degrees so you can quickly set the filter on your lens. Working with both a polarizer and a lens hood can be a bit of a hassle, though, with some configurations.
Steve
If you have only one polarizer in front of the lens you can't see what the effect will be (as you would with an SLR).
The second filter goes in front of your eye! You rotate it to get the effect you want, note the orientation, and set the same orientation on the lens filter.
All filters will act the same way (ie. light let through at 0 degrees and light blocked at 90 degrees. You can get a cheap filter for looking through.
And if you're using an external light meter remember that the filter basically blocks half of the light...
colin
