GIII QL17 : Aperture problems in A mode
Fabrice2
5:47 PM
France
I've read yesterday on a French forum, a guy with a canonet problem, in A mode, the needle shows 1,7 and the lens open to 2,8.
I checked one of my canonets and i got exactly the same problem, i noticed that this GIII QL17 is a different type from my other ones, it's written on the back "made in taiwan R.O.C" and there's a piece of plastic in the back, on my other GIII the piece is in iron.
May be this problem happens only with only those models??
There is a kind of delay (or decalage?sorry for my bad english) between the apertures and the meter, the meter is good but the aperture is wrong.When the needle say F4 it opens to 5.6, F11< F16, F16<~F16,2
The problem occurs only in A mode.
I though it was a meter problem, but the meter is accurate according to my leningrad 8.
There's not a lot of canonet specialist in France, so i ask for your help guys.
Got an idea?
First. What battery are you using?
Second. Check it against a different meter.
Three. Just how are you determining that the aperture is wrong?
1/i use a PX625 and i also try a wein air cell with a ring adapter.
2/The other metter i have is the one from an olympus xa.
3/i set the camera in B mode, point the camera to a bright object, when the needle is showing F4, i shoot, and watch the lens, i go on manual, put F4 and rewind,the blades opens to the real F4.
The needle shows the good aperture, but the lens wont open enough.
You have to be in manual to get proper B operation. The aperture is designed to use manual in B mode.
And the meter does not work in manual mode. 😉
Set the shutter speed to 1/500, 400iso in bright sunlight in A mode. Also test at 100, 200 iso in A mode.
B is for bulb, you know like dim bulb. You are not going to be shooting B speed in A mode.
Yes i know the meter doesn't work in manual mode.
To resume, If i want to shoot at 1,7 in Automatic mode, using the needle at 1,7 the lens won't open to 1,7 but ~2,8, in any speed, even B.
In manual everything works perfect.
I tried with a PX625 and the wein air A675, no real differences with the meter.
But the lens should do what the meter says, even if the meter reads high,isn't it?
The best way to use the camera is to read the meter in A mode and swith to manual and set the aperure to shoot.
If the meter is showing 2.8 in A mode, but the lens won't stop down that far. It sounds like a backyard meter adjustment was made.
The needle was bent to say what they wanted. It is a trap needle meter system.
If it syas one thing and does another, time for a fix.
i 've checked the needle yesterday, it's straight.
and when it goes in the red zone i can't shoot.
i should have red zone then f1.7, i have red zone then f2.8(the arrow shows 1.7).
They used another method i suppose.The meter screw??
Is it the good way to calibrate the meter to the new batteries?
Because there's a kind of regularity between the needle/lens.
There is no screw for adjusting the meter.
I don't have your camera in front of me. I can't tell what may be hacked on it.
The only mechanical way to screw up a meter is to start bending things.
But I know that unless a meter (handheld) has been verified against a known good source, it is worse than no meter.
If the meter is reading 2.8 and it is not at that aperture, something is bent. It is not an electrical problem.
I don't normally blow my own horn. But right now there are at least 6 people on the board who are using GIII's I rebuilt. Try the search function sometime. 😉
One little oddity I noticed: in A mode you can't see the iris stop down until you fire the camera; in manual mode if you don't re-cock the camera the iris will stop down as you go to smaller f-stops but if you go to a higher f-stops afterwards the iris wont open up again. Could this be affecting your tests? In other words before setting the f-stop in manual mode re-cock the camera otherwise you may not get a true picture. Of course it wouldn't hurt to take pictures in both manual and A mode and compare the results.
My canonet does a similar thing: the aperture readout in VF is ok compared to a known good handheld meter, but in A mode the aperture stops down more than that.
The reason is, that someone recalibrated the meter to read good with alkaline battery. But there is more voltage 1.5 vs. 1.35 and the higher voltage causes an electromagnet in the diaphragm stop-down mechanism to set smaller (higher f-stop number) actual aperture.
Only way to overcome this is to use manual mode. Or recalibrate the meter back and solder a diode in series to the battery to drop the supply voltage.
Hmm, this seems to be the same problem with my Canonet. Meter reads fine compared to other camera meters. However, in Auto, when it reads 1.7, apperture in reality won't fully open as it would in 1.7 manual mode. Otherwise, it works normally. The camera is with the repair guy for lens cleaning, I'll have to check again and verify if I have the problem when it gets back.
