goliathus
Thanks you for your checking ~NIKON KIU said:I don't have my 2005 camera here at work but do have my vintage 3.5cm f1.8. It is exactly like yours, when turning the whole lens in my finger 360 degrees,it is obvious that is the way it was designed.
Kiu
I can't understand why nikon design it in this unregularly way ~
goliathus
Ok vincec, I got itVinceC said:If you look inside the mount, what causes it is that large set-screw inside a deep slot. The machining of the edge of the slot affects the tilt.
Now that I stare at it, mine does tilt, very very very slightly. As I said before, this is inconsequential to the lens in use, because the sleeve slides back and forth when put into the focus mount. This spring-loaded movement is actually how the focus helical matches up with the built-in 50mm helical on the mount.
I say stop staring at un-mounted lenses. Put them on a camera and take pictures.
And finally I understood focusing mechanism of my nikon s2 with w-nikkor and 5cm/1.4 !!!
RFF nikon forum is full of experts and real gentleman ~
dreamsandart
Yes, and I have one of these 'defective' tilted new 1.8/35 Nikkors also
Its very interesting how these Nikon/Contax lens mounts work. Much more complicated then the Leica M-mounts I'm used to, but it works and the lens really locks on well and with the focusing it seems more uniform with individual lens.
Xmas
goliathus
It was Contax who designed the Contax I and then II to compete with Leitz, the famous quote is 'master piece of misplaced...'
Noel
Noel
yossi
I have the same lens, purchased new with the SP2005. No, I don't see any tilting.
(sorry, pix not well-taken.)
NIKON KIU
Did you say Nippon Kogaku
Yes you do!!
Kiu
Kiu
yossi said:I have the same lens, purchased new with the SP2005. No, I don't see any tilting.
Ahaaaaa! Hiding the tilt by blurring the background
ZivcoPhoto
yossi
jonmanjiro said:Ahaaaaa! Hiding the tilt by blurring the background![]()
Haha! That's so funny. I think some of us must be seeing things that other don't see. anyway, one more shot with smaller f-stop for viewing pleasure
NIKON KIU
Set the lens to infiniti and turn it 360 degrees
Ahaaaaa!!!
Kiu
Ahaaaaa!!!
Kiu
yossi
NIKON KIU said:Set the lens to infiniti and turn it 360 degrees
Ahaaaaa!!!
Kiu
Aaaah... now I see!! yes, turn it 360 degrees.
(Oh no, now I have a faulty w-nikkor !!
VinceC
The "tilt" is caused by the set screw holdling on the focus sleeve. Since that is incomprehensible, the red arrow below points to ths slot containing the large set screw. The amount of "tilt" depends on the machining of this slot. (Original picture posted by Kiu).
Xmas
If you guys dont stop I'll post a j12 picture.
Noel
Noel
VinceC said:(Original picture posted by Kiu).
Ahemmmm, that's my picture!
Here's the 360 degree view. See the tilt now
Slow speed!
VinceC
NIKON KIU
Show me if you dare!!!Xmas said:If you guys dont stop I'll post a j12 picture.
Noel
Kiu
goliathus
C'mon Xmas ~ we are waiting for your 'tilted J12' photo~~
Xmas
