Zenjitsuman
One lesson that a digital rf manufacture could take a lesson from the Nikon D3 is the 5:4 ratio frame size setting as a native sensor size.
Since prints to 8x10 and 16x20 have alway been popular the aspect ratio 5:4 is a good idea that allows direct composition on screen and no PP cropping to size final print. No wasted pixels cropped away.
Also, the 5:4 ratio equates to a 1.2 crop of a 35mm full frame. This makes the problem of vignetting less because 3mm is cropped from each side of a 35mm frame leaving a 30x24mm sensor size.
The affect on lenses is much better in regards to wide angles.
A 18mm lens ends up in 5:4 format being a 22mm lens
a 24mm lens is now 29mm lens and a 50mm lens is 60mm FL.
A 75mm lens is now 90mm lens.
I think this works out well. If someone will add in camera image stabilization and low noise ISO 1600 its a winning combination.
No shake to for sure 1/2 sec because to start with there is no moving mirror slap and image stabilization.
