Rhodes
Time Lord
Should I use it? Is there any way to test it besides a test roll?
Just clip off the leader of some film and throw it into developer at the dilution you plan to use. It should turn black after a couple of minutes. If it does, you can do a test roll to see if your development time is well suited for your subject. If not, discard and mix fresh.
Ben Marks
Can this be done in daylight or a room that is lit?
