richard_l
The new metal one.peter_n said:Richard are you using the current (metal) one that Cameraquest sells or the old (plastic) one?
Ooohh, dangerous waters ahead, Ted! The idea of limited DoF and seeing some bokeh in a 28mm is seductive too. Here's some commentary by Irwin Puts on the 28mm Ultron...tedwhite said:I'd love to have the 28/1.9. The only 28 I've got is a Super Takumar 3.5 on a Spotmatic body. Both the cv/25/4 and the ST 28/3.5 are wonderful lenses, but the low-light possibilities with a 1.9 are sucking me into a GAS vortex.
I haven't used mine wide open yet, but Puts sez that it's not quite as good at f/2 as the Summicron (well....duh 😛 ). However, stopped down a bit it is as good as the Summicron. Moreover, overall it is better than the older Leica 28mm lenses. (That doesn't stop me from wanting an Elmarit, however. 😀 )tedwhite said:Oh, and by the way, just how good is this cv 28/1.9? Obviously a fast lens, but we all know there are some definite "fast" duds out there.
Manolo Gozales said:Hey🙂
The widest frames on the R3a are 40mm; that's much wider than 28mm. So unless you want to have absolutley no idea what is going to be in shot, then yes you would need the aux finder.
However, as has already been stated, the outside edge of the R2/R2a viewfinder gives a rough approximation to a 28mm filed of view, although of course you wouldn't get any parallex correction. If it were me and I shot mainly wide angle, I would go for the R2/R2a over the R3a.
ManGo
Huck Finn said:...the ZI becomes a very attractive alternative even considering the price because of the parallax issue, the improved metering, quieter shutter, improved shutter control, longer base line, higher magnification, & better QC.
